Wired
VRRP on master and not establishing properly
  • 1.  VRRP on master and not establishing properly
    Posted Jan 07, 2021 12:09 PM
    Hi Team,
    we are configuring VRRP between two 8320 sswitches but we see the VRRP is not establshing properly, the VRRP betwwen VLAN is established only when the primary IP and the owner ip is same or else it is not working and when we test getting in INIT state.
    we want to establish like cisco model the two switch interface should have different IP and the Virtual IP should be different, is there any way to do it.
    int vlan 10  - 10.7.10.3 in one switch
    int vlan 10 - 10.7.10.4 on other switch but the primary IP should be 10.7.10.5 so please help us on how to do it.
    V M Santhana Krishnan
  • 2.  RE: VRRP on master and not establishing properly
    Posted Jan 08, 2021 03:42 AM
    1) Did you open a TAC ticket ?
    2) please share the detailed configuration of the SVI of VSX primary and of VSX secondary.
    Vincent Giles
