VRRP on Mobility Masters - AOS 8.2.0.1
  • 1.  VRRP on Mobility Masters - AOS 8.2.0.1
    Posted Nov 13, 2017 03:54 AM
    Hi all,
    I'm testing VRRP on 2 Mobility Masters (MM)
    I have 2 MMs:
    - MM-01: Preferred-Master (Priority 200)
    - MM-02: Backup (Priority 100)
    I have configured a VR ID and Master Redundancy. But when I show on the cli, They're both Master state.
    - They are time synchronized, ping each other ok.
    My configuration is below
    MM-01MM-01MM-01MM-01MM-01MM-01MM-02MM-02MM-02MM-02MM-02MM-02
    Please help me on this issue.
    Thanks a lot :)
  • 2.  RE: VRRP on Mobility Masters - AOS 8.2.0.1
    Posted Nov 13, 2017 08:58 AM
    Are these virtual MMs?
    Get Outlook for iOS
  • 3.  RE: VRRP on Mobility Masters - AOS 8.2.0.1
    Posted Nov 13, 2017 08:08 PM
    Yep, I use virtual Mobility Master.
  • 4.  RE: VRRP on Mobility Masters - AOS 8.2.0.1
    Posted Nov 13, 2017 08:40 PM
    Here is my configuration.
    Both of them are VR Master so Mac address of VRRP IP is changed between 2 interface physical of 2 MMs. The controller couldn't join MM.
    Please help me on this case.
    Thanks a lot
    Attachment(s)
    txt
    MM-02-1.txt   40 KB 1 version
    txt
    MM-01-1.txt   40 KB 1 version
  • 5.  RE: VRRP on Mobility Masters - AOS 8.2.0.1
    Posted Nov 13, 2017 10:21 PM
    Did you enabled forged transmit ? It is required to be enabled so that VRRP can work
    Get Outlook for iOS
  • 6.  RE: VRRP on Mobility Masters - AOS 8.2.0.1
    Posted Nov 13, 2017 11:03 PM
    Ye ye, It works :)
    I changed to accept on Forged Transmits option and now It works
    Thanks a lot, Victor.
  • 7.  RE: VRRP on Mobility Masters - AOS 8.2.0.1
    Posted Apr 20, 2018 10:11 AM
    Hi, I have a problem familiar this topic
    But I enabled Forged Transmit already but Mobility Master still Master/Master state
    * If not activate license , can cause this problem ?
