VRRP Redundancy Failover
  • 1.  VRRP Redundancy Failover
    MVP
    Posted Aug 21, 2013 11:18 PM
    Hey AirHeads Community,
    So here's the scenario:
    Two 7210 controllers in an Active-Master (Master1) / Backup-Master (Master2) VRRP redundancy configuration. Pre-emption is NOT checked in the VRRP addresses. Master1 has a priority of 110, Master2 has a priority of 100. When testing failover, the APs failed from Master1 to Master2 perfectly. However, when Master1 came back online, the APs went back to Master1. Again, Pre-emption is NOT checked and I cannot figure out why the APs went back to Master1. First time rebooting, I did it from GUI, second time rebooting I pulled the power cords from controller. Same result, APs came back to Master1.
    Controllers are running 6.2.1.3 code
    I do not want the APs to go back to Master1 in a failover scenario. Any ideas why this might be happening?
    Thanks!
    Ps. Attached is a picture of VRRP configuration to show that Pre-emption is NOT checked.
    #7210
  • 2.  RE: VRRP Redundancy Failover
    Posted Aug 21, 2013 11:33 PM
    Despite having preemption disabled, does the first controller regain "master" status of the VRRP when coming back online?
    You can also shutdown the VRRP intances on the master (rather than rebooting) to test this failover.
    config t
    vrrp <id>
    shut
    show vrrp (verify it is in INT state)
    verify that the other controller is master for this IP
    show vrrp (verify it is Master)
    bring the master back online
    config t
    vrrp <id>
    no shut
    show vrrp (verify status; should stay Backup)
    Also, can you confirm what you have set for your primary/backup LMS in the AP System profile for those APs?
  • 3.  RE: VRRP Redundancy Failover
    MVP
    Posted Aug 21, 2013 11:39 PM
    Yes, the controller takes the Master role back although preemption is not checked.
    No LMS IP defined in AP system profile.
    Thanks!
    Just some more detailed info:
    Active-Master 172.30.10.27
    Backup-Master 172.30.10.28
    VRRP 172.30.10.26
  • 4.  RE: VRRP Redundancy Failover
    Posted Aug 22, 2013 12:31 AM
    just to clarify, you have no IP in the LMS field?  your primary LMS in your case should be 172.30.10.26; the VRRP address.  If it is blank, they will terminate on the controller from discovery by default.  Please confirm your setting.
  • 5.  RE: VRRP Redundancy Failover
    MVP
    Posted Aug 22, 2013 08:59 AM
    Yes LMS is blank. That wouldn't cause the active-master to take back the virtual IP for the VRRP, would it?
  • 6.  RE: VRRP Redundancy Failover
    Posted Aug 22, 2013 04:48 PM
    no it should not, but it may account for the APs going back.   these are master/master, correct?
    can you run the following on each controller:
    show vrrp
    show master-redundancy
  • 7.  RE: VRRP Redundancy Failover
    MVP
    Posted Aug 22, 2013 04:51 PM
    Yes they are master/master setup.
    I currently don't have access to the controllers, but I'm going to paste the config below:
    Active-Master:
    master-redundancy
    master-vrrp 10
    peer-ip-address 172.30.10.28 ipsec 77db8ba3817b029922e150f79fcbbeeb8d68ca677bb30755
    vrrp 10
    priority 110
    authentication aruba123
    ip address 172.30.10.26
    vlan 10
    tracking master-up-time 30 add 20
    no shutdown
    Backup-Master:
    master-redundancy
    master-vrrp 10
    peer-ip-address 172.30.10.27 ipsec 0464b861ed6ff4f3cc1c00dafa967be7f4bba843c12c78a7
    vrrp 10
    description "Backup-Master"
    vlan 10
    no shutdown
  • 8.  RE: VRRP Redundancy Failover
    Posted Aug 22, 2013 05:32 PM
    the configuration looks correct from what you copied.   there should be an entry in the logs for the VRRP transition.   Can you check the logs on both; it should show up in the system log;  show log system all | include vrrp
    show vrrp <id> statistics on both will also show details about priorities received, etc.  It may help tracking it down.
    if there is not enough try turning on debugging
    logging level debugging system subcat messages process fpapps
    don't foget to turn it off later
    no logging level debugging system subcat messages process fpapps
  • 9.  RE: VRRP Redundancy Failover
    Posted Jan 16, 2014 03:34 AM
    Hi MHaring,
    I got exactly the same issue. Did you find any solution ot fix it?
    Thanks you
  • 10.  RE: VRRP Redundancy Failover
    Posted Jul 18, 2016 02:38 PM
    Found any solution ?
  • 11.  RE: VRRP Redundancy Failover
    Posted Jul 20, 2016 09:47 AM
    Does the same occur if you remove the tracking from the VRRP configuration?
