vrrp takeover with no preempt enable
  • 1.  vrrp takeover with no preempt enable
    Posted Jul 03, 2012 11:36 PM
    Hi
     Our controller detected vrrp transition trap, but it didin't takeover actually in show vrrp and the rest of syslog. But syslog message displyes three hellos were dropped. So it should have taken over(the threshold is three, right?). I hope old standby changed to new master and remain there in preempt disabled after three hellos ware dropped. Do anyone have any idea if it didn’t take over in spite of three heartbeat misses?
    <syslog>
    17x.2x.2.248 Jul  1 09:34:11 2012 [17x.2x.2.247] fpapps[1547]: <313333> <ALRT> |fpapps|  VRRP: vrid "100"(Master) - Received VRRP Advertisement with LOWER PRIORITY (100) from 17x.2x.2.250, ignoring.
    17x.2x.2.250 Jul  1 09:34:11 2012 [17x.2x.2.249] fpapps[1548]: <313328> <WARN> |fpapps|  vrrp: vrid "100" - VRRP state transitioned from BACKUP to MASTER
    17x.2x.2.250 Jul  1 09:34:11 2012 [17x.2x.2.249] fpapps[1548]: <306502> <INFO> |fpapps|  Publish service 'VRRP_STATE', object len 20
    17x.2x.2.250 Jul  1 09:34:11 2012 [17x.2x.2.249] fpapps[1548]: <313330> <INFO> |fpapps| Sending Role change event to CFGM
    17x.2x.2.248 Jul  1 09:34:11 2012 [17x.2x.2.247] cfgm[1368]: <399815> <INFO> |cfgm|  Connection went down withlocal 17x.2x.2.249 socketID: 14, errno_str:Success
    17x.2x.2.248 Jul  1 09:34:11 2012 [17x.2x.2.247] cfgm[1368]: <399815> <INFO> |cfgm|  Closing Socket 14 Connection with Local 17x.2x.2.249, master-local transport type 4
    17x.2x.2.248 Jul  1 09:34:11 2012 [17x.2x.2.247] cfgm[1368]: <399815> <INFO> |cfgm|  Switch 17x.2x.2.247 role master, Resetting Socket 14 connection for 17x.2x.2.249 transport type TCP cfgUpdateState UPDATE SUCCESSFUL
    17x.2x.2.250 Jul  1 09:34:11 2012 [17x.2x.2.249] fpapps[1447]: <399815> <INFO> |fpapps|  fpappsCB: msgPvtPart 0x129c4c00 err 0 MsgCode 11000 DestPtNm 8378 DestIp 127.0.0.1 PckTy 1
    17x.2x.2.250 Jul  1 09:34:11 2012 [17x.2x.2.249] cfgm[1369]: <399815> <INFO> |cfgm|  Switch 17x.2x.2.249 Role master will reset all local connection, may be due to VRRP rolechange
    17x.2x.2.250 Jul  1 09:34:11 2012 [17x.2x.2.249] fpapps[1548]: <313331> <WARN> |fpapps|  VRRP: vrid "100" - Missed 3 Hello Advertisements from VRRP Master 17x.2x.2.250
    17x.2x.2.250 Jul  1 09:34:11 2012 [17x.2x.2.249] cfgm[1369]: <307218> <INFO> |cfgm|  CFGM IPSEC   src_net:0.0.0.0:0.0.0.0 dst_net:0.0.0.0:0.0.0.0 vlan:0
    17x.2x.2.250 Jul  1 09:34:11 2012 [17x.2x.2.249] cfgm[1369]: <399815> <INFO> |cfgm|  Switch 17x.2x.2.249 role master config state UPDATE SUCCESSFUL, Closing Socket 13 connection
    17x.2x.2.250 Jul  1 09:34:11 2012 [17x.2x.2.249] fpapps[1548]: <313328> <WARN> |fpapps|  vrrp: vrid "100" - VRRP state transitioned from MASTER to BACKUP
    17x.2x.2.250 Jul  1 09:34:12 2012 [17x.2x.2.249] localdb[1475]: <133072> <INFO> |localdb|  Received master IP response 17x.2x.2.251, switch role 2. Old IP 17x.2x.2.251, old switch role 4
    17x.2x.2.250 Jul  1 09:34:12 2012 [17x.2x.2.249] authmgr[1473]: <399815> <INFO> |authmgr|  Set MASTER IP to 17x.2x.2.251
    17x.2x.2.250 Jul  1 09:34:12 2012 [17x.2x.2.249] localdb[1475]: <133113> <INFO> |localdb| Querying local switch list
    17x.2x.2.250 Jul  1 09:34:12 2012 [17x.2x.2.249] authmgr[1473]: <399815> <INFO> |authmgr|  Set Switch Role to master
    17x.2x.2.250 Jul  1 09:34:12 2012 [17x.2x.2.249] fpapps[1548]: <313332> <WARN> |fpapps|  VRRP: vrid "100"(Master) -  Received VRRP Advertisement with HIGHER PRIORITY (110) from 17x.2x.2.248
    17x.2x.2.250 Jul  1 09:34:12 2012 [17x.2x.2.249] fpapps[1447]: <399815> <INFO> |fpapps|  fpappsCB: msgPvtPart 0x129c5c00 err 0 MsgCode 7005 DestPtNm 8224 DestIp 127.0.0.1 PckTy 1
    17x.2x.2.250 Jul  1 09:34:12 2012 [17x.2x.2.249] cfgm[1369]: <399815> <INFO> |cfgm|  Switch 17x.2x.2.249 Role standby will reset all local connection, may be due to VRRP rolechange
    <master>
    master-redundancy
      master-vrrp 100
      peer-ip-address 17x.2x.2.249 ipsec xx
    vrrp 100
      priority 110
      ip address 17x.2x.2.251
      vlan 3002
      no shutdown
    <backup>
    master-redundancy
      master-vrrp 100
      peer-ip-address 17x.2x.2.247 ipsec xx
    vrrp 100
      vlan 3002
      no shutdown
    - 5.0.3.3
    Regards
    Saimon
    #7005
  • 2.  RE: vrrp takeover with no preempt enable
    Posted Jul 04, 2012 05:23 AM
    What is the priority of the backup?
    How are the controllers physically connected to your infrastructure?  Are they connected via trunk?  Do you use spanning tree?
    What is the output of "show vrrp 100 statistics" on both sides?
  • 3.  RE: vrrp takeover with no preempt enable
    Posted Jul 04, 2012 11:23 PM
    Hi Cjoseph
    What is the priority of the backup? -> Master 110 and Backup 100
    How are the controllers physically connected to your infrastructure?  ->Both are connected to same L3 switch.
    Are they connected via trunk?  -> It is trunk ports.
    Do you use spanning tree? -> No
    (Primary) #show vrrp 100 statistics
    Virtual Router 100:
       Admin State UP, VR State MASTER
       Advertisements:
       Sent:                         28837523   Received:                       867
       Zero priority sent:                  3   Zero priority received:           0
       Lower IP address received            0   Lower Priority received         867
       Tracking priority overflow:          0
       Advertisements received errors:
          Interval mismatch                 0   Invalid TTL                       0
          Invalid packet type               0   Authentication failure            0
          Invalid auth type                 0   Mismatch auth type                0
          Invalid VRRP IP address           0   Invalid packet length             0
       VRRP Up timestamp:                       Fri Aug 12 16:56:52 2011
       Master Up timestamp:                     Fri Aug 12 16:56:56 2011
       Last advertisement sent timestamp:       Thu Jul  5 11:28:11 2012
       Last advertisement received timestamp:   Fri Aug 12 16:56:56 2011
       Current time:                            Thu Jul  5 11:28:11 2012
       Number times became VRRP Master:         4
    (Backup) #show vrrp 100 statistics
    Virtual Router 100:
       Admin State UP, VR State BACKUP
       Advertisements:
       Sent:                           142506   Received:                  28844313
       Zero priority sent:                  5   Zero priority received:           0
       Lower IP address received     28844313   Lower Priority received           0
       VRRP Up timestamp:                       Fri Aug 12 17:14:38 2011
       Master Up timestamp:                     N/A, not MASTER
       Last advertisement sent timestamp:       Fri Aug 12 16:58:26 2011
       Last advertisement received timestamp:   Thu Jul  5 11:29:19 2012
       Current time:                            Thu Jul  5 11:29:19 2012
    Any comment is appreciated.
    Regards
    Simon
  • 4.  RE: vrrp takeover with no preempt enable
    Posted Jul 05, 2012 05:40 AM
    the "Number of Times it became master" is cut off from the backup.  In addition, it looks like the backup thinks it was the master for a great deal of time.
    You might want to open a case so they can troubleshoot the backup's inability to see the master controller....
  • 5.  RE: vrrp takeover with no preempt enable
    Posted Jul 06, 2012 07:35 AM
    Cjoseph
    I am sorry the number of times was cut off.  It was 9.
       Number times became VRRP Master:         9
    Anyway, I come to understand the condition gradually, so I can explain why trap was sent.
    No need to open case for this.
    Regards
    Simon
