Wired Intelligent Edge
VRRP with 4x 8320 ?
  • 1.  VRRP with 4x 8320 ?
    Posted Aug 23, 2019 09:24 AM
    Hey all,
    one short question..
    The Datasheet from the Aruba 8320 says:
    VRRP
    Allows groups of two routers to dynamically back each other up to create highly available routed environments.
    Normally i can create a VRRP with more than two routers. Is there really this limitation or can i create a VRRP with four 8320 Switches?
    thank you!
  • 2.  RE: VRRP with 4x 8320 ?
    Posted Aug 23, 2019 09:31 AM
    2 or more. p255 of routing guide.
  • 3.  RE: VRRP with 4x 8320 ?
    Posted Aug 23, 2019 09:42 AM
    soo.. there is really an error in the datasheet?
    thank you!
  • 4.  RE: VRRP with 4x 8320 ?
    MVP GURU
    Posted Aug 27, 2019 09:44 AM
    Yes, it is no often used with  more of 2 switchs.
    You can use also Active-Gateway with 4x8320;;;
  • 5.  RE: VRRP with 4x 8320 ?
    MVP GURU
    Posted Aug 27, 2019 11:36 AM
    Not a real error IMHO...describing VRRP from a generic standpoint...writing it will use just two routers is an omission: instead of simply stating "two routers" that sentence should have been more properly "two or more routers".
