Wired Intelligent Edge
VSF Configuration with 1 Gig copper interface
  • 1.  VSF Configuration with 1 Gig copper interface
    Posted Dec 06, 2017 11:44 PM
    Need to know wether 2930f support vsf on 1gig.
    Regards
    ThangarajRajendran
  • 2.  RE: VSF Configuration with 1 Gig copper interface
    Posted Dec 08, 2017 08:45 PM
    Hi Thangaraj,
    The answer to your question is no.
    VSF can be achived only using 10gig and 40gig.
    Lokesh
  • 3.  RE: VSF Configuration with 1 Gig copper interface
    Posted Dec 11, 2017 05:33 AM
    Hi Thangaraj,
    I think 1Gbit can be used for VSF. In the past this didn't work but since the latest firmware release (WC.16.04.0010) it should. I haven't test this myself.
    Copy from the release notes.
    VSF CR_0000238068
    Symptom: The switch fails to form a VSF stack when using a 1G connection for a VSF switch link.
    Scenario: The switch fails to form the VSF stack when the VSF link is configured for a 1G interface. The standby switch reboot process triggered by the stack role election process hangs at "Initializing…"., while the commander switch reports a warning event log message similar to: I 01/01/90 00:04:00 03279 stacking: ST1-CMDR: Member 2 (941882-11c860) chosen as standby.Reason: Only available standby W 01/01/90 00:06:03 03838 chassis: ST1-CMDR: Co-Processor failed to boot. Timeout reached: System initialization failure
    Workaround: Configure the VSF link on 10G interfaces.
    Willem
  • 4.  RE: VSF Configuration with 1 Gig copper interface
    Posted Dec 12, 2017 04:04 PM
    Aruba 2930F Switch Series do support VSF on 1G and 10G interfaces. You can use RJ45 1G ports or 1G SFP, or 10G SFP+ to support VSF stacking. The reference here to an issue in one particular release, which is about to be fixed with a new release.
    They have always been able to stack with 1G ports, as long as VSF has been supported.
  • 5.  RE: VSF Configuration with 1 Gig copper interface
    Posted Dec 13, 2017 06:24 PM
    tested it using rj45 and it works as long as your image is 16.03 or higher... aruba 2930f switch I used.
