Atmosphere 2021
last person joined: 10 days ago
VSF link between 2 Aruba 6300M 48MRate JL659A switches
  • 1.  VSF link between 2 Aruba 6300M 48MRate JL659A switches
    Posted 22 days ago
    Hi, I want to know  Can i use any switch port from number 1 to 48 to make VSF link between 2 Aruba 6300M 48MRate JL659A switches? I will use normal cat 6A cable between switches. no special cable.
  • 2.  RE: VSF link between 2 Aruba 6300M 48MRate JL659A switches
    Posted 14 days ago
    https://www.arubanetworks.com/techdocs/AOS-CX/10.13/PDF/vsf.pdf
    6300: VSF allows stacks to be formed using any combination of SKUs of the 6300 family. Up to 10 member switches will be allowed. Connections between the switches must use 10G, 25G, or 50G links. All VSF links in a stack should operate at the same speed.
    The VSF stack, containing only the S0E91A and S0X44A SKUs, supports 10G, 25G, and 100G speed links. If a VSF stack includes a mix of S0E91A/S0X44A SKU and other SKUs, then it supports 10G and 25G VSF links only.
