Wired Intelligent Edge
VSF links: can some links be rearranged without issues?
  • 1.  VSF links: can some links be rearranged without issues?
    MVP GURU
    Posted Jul 25, 2019 05:02 AM
     Cheers,
    I have a (silly) doubt...actually our Aruba 5400R zl2 VSF is deployed with this VSF Links configuration (4 DAC Cables = 4x10Gbps = 40 Gbps):
    VSF# show vsf link detail
    VSF Member: 1 Link: 1
    Port State
    1/C7 Up: Connected to port 2/C7
    1/C8 Up: Connected to port 2/C8
    1/D7 Up: Connected to port 2/D7
    1/D8 Up: Connected to port 2/D8
    VSF Member: 2 Link: 1
    Port State
    2/C7 Up: Connected to port 1/C7
    2/C8 Up: Connected to port 1/C8
    2/D7 Up: Connected to port 1/D7
    2/D8 Up: Connected to port 1/D8
    We realized that crossing some of the links (at least two - C8 and D8 on each VSF Member - of the total four each VSF Port has) would be better from the resiliency standpoint (in case one or two VSF Member's module(s) would hit a serious issue) leaving us - at worst - with one 10Gbps VSF Links between VSF Members:
    Port State
    1/C8 Up: Connected to port 2/D8
    1/D8 Up: Connected to port 2/C8
    Port State
    2/C8 Up: Connected to port 1/D8
    2/D8 Up: Connected to port 1/C8
    So...can I rearrange /C8 and /D8 physical links (reseating related DAC Cables) leaving untouched /C7 and /D7 ones without any particular issue from the VSF Ports standpoint?
    The answer should be a sound "Yes"...but it worths a double check.
  • 2.  RE: VSF links: can some links be rearranged without issues?
    Posted Jul 25, 2019 11:04 AM
    Greetings!
    In the case of the 5400R, because there can only be one other member, you can connect any physical VSF port on one member to any other VSF port on the other member. You can even swap VSF ports while the stack is operating without causing an interruption in operation as long as at least one VSF link interface remains active at all times.
  • 3.  RE: VSF links: can some links be rearranged without issues?
    MVP GURU
    Posted Jul 25, 2019 12:57 PM
    Hello Matthew! thanks for confirming my very same toughts banishing my doubt...considering the special Aruba 5400R zl2 VSF deployment case...that was what I expected too. Great.
