Wired Intelligent Edge
last person joined: 3 hours ago
VSF on 5406/5412 with OS 16.08
  • 1.  VSF on 5406/5412 with OS 16.08
    Posted Apr 24, 2019 10:10 AM
    Hi all,
    in the early times of VSF it was not possible to mix different switch models in a VSF domain.
    When I check the configuration guide for OS 16.08 (VSF Restrictions) the point "only same switch model" is not there any more.
    Does that mean that I can now configure a 5406R and a 5412R into one VSF domain or is that still not possible?
    Is there a document that describes the supported switch combinations for a VSF?
    Regards
  • 2.  RE: VSF on 5406/5412 with OS 16.08
    Posted Apr 24, 2019 12:13 PM
    It is still the same in the case of the 5400R Switch Series, you cannot mix modes, you can either use 2 x 5406R or 2 x 5412R, up to 2 members in a VSF stack.
    This is not the case with the 2930F Switch Series, you CAN mix and match those up to 8 members in a VSF stack.
    We will work with the doc team to ensure that's properly reflected in the documentation.
    Justin
  • 3.  RE: VSF on 5406/5412 with OS 16.08
    Posted Apr 25, 2019 05:36 AM
    Hi Justin,
    thanks for your explanation.
