Wired Intelligent Edge
VSF Port Mismatch over DAC Cabel
  • 1.  VSF Port Mismatch over DAC Cabel
    Posted Nov 26, 2018 08:09 AM
    Hey,
    we have a 3 member 2930f stack and a problem between member 2 and 3. One port ist down and the other side is down with Error: Port speed mismatch. This is the vsf config:
    switch(config)# sh vsf
     VSF Domain ID    : 1
     MAC Address      : 089734-ab460b
     VSF Topology     : Chain
     VSF Status       : Active
     Uptime           : 1d 22h 7m
     VSF MAD          : None
     VSF Port Speed   : 10G
     Software Version : WC.16.07.0002
     Mbr
     ID  MAC Address       Model                                 Pri Status
      1  089734-ab4600     Aruba JL558A 2930F-48G-740W-PoE+-4... 255 Commander
      2  089734-ab6400     Aruba JL558A 2930F-48G-740W-PoE+-4... 128 Member
      3  089734-abd0c0     Aruba JL558A 2930F-48G-740W-PoE+-4... 128 Standby
    nsrb845k1(config)# sh vsf link detail
     VSF Member: 1     Link: 1
     Port     State
     1/52     Up: Connected to port 2/51
     VSF Member: 1     Link: 2
     Port     State
     1/51     Up: Connected to port 3/52
     VSF Member: 2     Link: 1
     Port     State
     2/51     Up: Connected to port 1/52
     VSF Member: 2     Link: 2
     Port     State
     2/52     Down
     VSF Member: 3     Link: 1
     Port     State
     3/51     Error: Port speed mismatch
     VSF Member: 3     Link: 2
     Port     State
     3/52     Up: Connected to port 1/51
    nsrb845k1(config)#
    We already tried another DAC cable but with no effect. Also set the vsf port speed to 10g.
    Kind regards
    Daniel
  • 2.  RE: VSF Port Mismatch over DAC Cabel
    MVP GURU
    Posted Nov 26, 2018 11:19 AM
    A (sanitized, without S/Ns) show tech transceivers CLI Comman's output would help
  • 3.  RE: VSF Port Mismatch over DAC Cabel
    Posted Nov 28, 2018 04:42 AM
    Cmd Info : show tech transceivers
    transceivers
    Transceiver Technical Information:
     Port # | Type      | Prod #     | Serial #         | Part #
     1/49   | 1000SX    |     J4858D | xxx       | 1990-4395
     1/51   | SFP+DA1   |     J9281D | xxx       | 8121-1300
     1/52   | SFP+DA1   |     J9281D | xxx       | 8121-1300
     2/51   | SFP+DA1   |     J9281D | xxx       | 8121-1300
     2/52   | SFP+DA1   |     J9281D | xxx       | 8121-1300
     3/50   | 1000SX    |     J4858D | xxx       | 1990-4395
     3/52   | SFP+DA1   |     J9281D | xxx       | 8121-1300
    show time
    Wed Nov 28 10:40:29 2018
    === The command has completed successfully. ===
    Here is the tech output. I also have a show tech all in the backhand.
  • 4.  RE: VSF Port Mismatch over DAC Cabel
    MVP GURU
    Posted Nov 28, 2018 04:56 AM
    Why do you have some 1000SX interface ?
    the speed need be the same on the VSF.
  • 5.  RE: VSF Port Mismatch over DAC Cabel
    MVP GURU
    Posted Nov 28, 2018 05:18 AM
    AFAIK...interfaces 1/49 and 3/50 don't play a role into his VSF deployment...so far, so good with those 1000SX interfaces.
    All other VSF involved ports are connected to DACs.
  • 6.  RE: VSF Port Mismatch over DAC Cabel
    MVP GURU
    Posted Nov 28, 2018 05:19 AM
    Oups...
  • 7.  RE: VSF Port Mismatch over DAC Cabel
    Posted Nov 28, 2018 06:07 AM
    The 1/49 and 3/50 are our uplink ports to the distribution,
  • 8.  RE: VSF Port Mismatch over DAC Cabel
    MVP GURU
    Posted Dec 10, 2018 08:12 AM
    You have always the issue ?
    What your VSF configuration (show run and vsf stuff ?)
