Wired Intelligent Edge
VSF Stack
  • 1.  VSF Stack
    Posted Oct 09, 2023 11:30 AM
    We have 4 x Aruba 6300M. I have created a stack, and all working as planned :) So my question is, can each switch still have its own IP? ALl switches are managed through the conducter, which I understand, but I still want to log in to each switch itself via IP on my network
  • 2.  RE: VSF Stack
    MVP GURU
    Posted Oct 09, 2023 02:37 PM
    You can do this with VSX, but not with VSF. You could use out of band management with a separate IP if you want to check on, or set up monitoring that way.
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022-2023
  • 3.  RE: VSF Stack
    Posted 7 hours ago
    Hi
    I have a 6300 with a live config that needs to be converted to a conductor. The documentation suggests that the switch need to be reset back to factory. Is there a way of making this switch conductor while maintain the existing config. I will have a short down time window and don't want to find myself having to redo the config.
