Wired Intelligent Edge
VSF Stacking on 2930f
This thread has been viewed 169 times
  • 1.  VSF Stacking on 2930f
    Posted Sep 13, 2017 11:43 AM
    Can i do VSF stacking between a 2930F of 24P POE with a 2930F of 48P Poe???
    Cheers
    Carlos
    #2930F
  • 2.  RE: VSF Stacking on 2930f
    Posted Sep 13, 2017 01:48 PM
    Yes, you can make a VSF stack using different 2930f models.
    http://h20566.www2.hpe.com/hpsc/doc/public/display?docId=c05365316 page 605
    The VSF feature allows the user to form a stack of up to four devices of any SKU, including mixing the SKUs in a single stack. The switches in these stacks are interconnected using standard Ethernet connections. These interconnections between member switches are called VSF links.
  • 3.  RE: VSF Stacking on 2930f
    Posted Sep 14, 2017 12:38 AM
    Yes, you can stack up to 4 units with any model of the family of 2930F
  • 4.  RE: VSF Stacking on 2930f
    Posted Oct 04, 2017 07:10 AM
    It-is possible to setup a stacking with four 2930 F with Copper 1 Gb and fiber 10 Gb like this ? Two 2930F interconnected with two Copper 1 Gb in a room . Two other  2930F interconnected with two Copper 1 Gb in a second room and the two rooms interconnected with fibre 10 Gb.
                        (one OM4 10 G)
    2930F --------------------------------2930F
      I |                                                | |
      I |  (two  Copper 1 gb)                 | |  ( two  Copper 1 gb)
                     (one   OM4 10 Gb)
    Thanks a lot,
    Hervé
  • 5.  RE: VSF Stacking on 2930f
    Posted Oct 04, 2017 11:38 AM
    Hi, sadly, no ... but its a good idea!
    At least you can do link aggregation between the rooms.
    Look at page 653 from here
    VSF restrictions
    • VSF is mutually exclusive with distributed trunking, mesh, and Q-in-Q.
    • VSF port restrictions:
        ◦ Must be 10Gbps/1Gbps.
        ◦ A VSF link can only comprise ports with the same speed; either all 10G or all 1G. A VSF port’s speed which does not match with the global port speed, will be in a down state. The command show vsf link detail will display an error message.
        ◦ Maximum eight ports can be configured on one VSF link.
        ◦ VSF ports must be directly connected and there should be no transit devices between members.
    • In a VSF virtual chassis, flow-control is not supported between ports on different chassis across VSF links.
    • A VSF stack downgrade is not allowed if we try to downgrade a 2930 VSF stack to a 16.02 image.
  • 6.  RE: VSF Stacking on 2930f
    Posted Oct 04, 2017 11:54 AM
    Ok..
    Or i replace  copper by fiber and it s ok but i have note fiber port availbale.
    And if i do link aggregation between the rooms, i have two VSF stacking, one  VSF in each room. It is possible to do VRRP between these VSF ?
    Thanks a lot,
    Hervé
  • 7.  RE: VSF Stacking on 2930f
    Posted Oct 04, 2017 12:06 PM
    Yes, VRRP is supported.
    Routing Manual page 241
  • 8.  RE: VSF Stacking on 2930f
    Posted Oct 04, 2017 12:21 PM
    ok thanks a lot.
  • 9.  RE: VSF Stacking on 2930f
    Posted Jan 21, 2018 08:06 AM
    hi sorry, does this mean that 1Gbps or 10Gbps is supported for VSF stack for 2930F series?
    1Gbps is workable? I am looking into 2 units of 2930F 24G SFP to perform VSF stack.
    Please advice, thank you
  • 10.  RE: VSF Stacking on 2930f
    Posted Jan 22, 2018 10:03 AM
    Yes, you can configure VSF using 1G links over 2930F.
  • 11.  RE: VSF Stacking on 2930f
    Posted Jan 26, 2018 12:52 AM
    yes, i've tested and it works. so is possible. thanks
  • 12.  RE: VSF Stacking on 2930f
    Posted Mar 27, 2019 12:48 PM
    Plese tell me how...
    i want to do the same. two 2930F just with SFP (not SFP+) and VSF Stacking.
    Best
  • 13.  RE: VSF Stacking on 2930f
    Posted Oct 08, 2018 11:07 AM
    Dears
    Can you please let me know if i have THREE 2930F switches and i want to stack them(VSF) so what commands should i run on each switch to put all of them in stack. Kindly share the step by step commands.
    Cheers
    Umer
  • 14.  RE: VSF Stacking on 2930f
    Posted Oct 17, 2018 06:58 PM
    I just recently did a setup with 3 switches and finally got them to stack correctly.   Here is the post that helped me - Configure Virtual Switching Framework (VSF) the easy way
    basically you configure the port that you will use as the uplink to a Link port (vsf member # link # <port>) and then connect the new switch to that port  while the new switch is off.  Then power it on and it should be detected and setup in the VSF.
    When you are ready to link them into a loop, you can then add a second Link port with a different number (1-2) and then connect the cables.  To get the loop to detect it MAY take a reboot.
