Wired Intelligent Edge
vsx-configmate command inconstancies
This thread has been viewed 38 times
  • 1.  vsx-configmate command inconstancies
    Posted Jun 28, 2021 07:14 AM
    Excuse the spelling mistake - vsx-configmate inconsistency
    Using the vsx-config mate command on a VSX pair and the output is showing as skipped although the config looks 100%, does skipped mean its failed the test or something else?
    Version is 10.05.0011 and it appears to be skipped due to not VSX peer not being ready. Is this a firmware issue or a bug in the command?
    SWITCH-002# vsx-configmate
    VSX FEATURE CONFIG PARSER
    VSX configuration validation results below:-
    Rule-1: The allowed VLAN list for ISL port must match that in config for MCLAG in SWITCH-002 (Passed)
    Rule-1: The allowed VLAN list for ISL port must match that in config for MCLAG in sw2 (Skipped)
    Rule-2: The native VLAN must also be part of allowed VLAN list for a MCLAG in SWITCH-002 (Passed)
    Rule-2: The native VLAN must also be part of allowed VLAN list for a MCLAG in sw2 (Skipped)
    Rule-3: The inter-switch-link Timers should be consistent across VSX peers (Skipped)
    Rule-4: The Keep-Alive Timers should be consistent across VSX peers (Skipped)
    Rule-5: Active-Gateway configurations(IP, MAC and VRF) should be consistent across the VSX peers (Skipped)
    Rule-6: The Keep-Alive UDP port should be consistent across VSX peers (Skipped)
    Rule-7: The link-up-delay-timer should be consistent across VSX peers (Skipped)
    Rule-8: The VSX System-MAC should be consistent across VSX peers (Skipped)
    Rule-9: The VSX device roles should be consistent across VSX peers (Skipped)
    Rule-10: VSX active-forwarding configurations should be consistent across the VSX peers (Skipped)
    SWITCH-002#
    Andrew Partridge
  • 2.  RE: vsx-configmate command inconstancies
    Posted Jun 29, 2021 04:14 AM
    Hi Andrew,
    I did a quick research and I am not able to find any information from the guides regarding the "configmate" command.
    I have tried it on one lab VSX (not in production) with a bit newer version (8320 TL.10.05.0021 – outdated version as well):
    VSX1-SW1(config)# vsx-configmate
    Rule-1: The allowed VLAN list for ISL port must match that in config for MCLAG in VSX1-SW1 (Skipped)
    Rule-1: The allowed VLAN list for ISL port must match that in config for MCLAG in VSX1-SW2 (Skipped)
    Rule-2: The native VLAN must also be part of allowed VLAN list for a MCLAG in VSX1-SW1 (Skipped)
    Rule-2: The native VLAN must also be part of allowed VLAN list for a MCLAG in VSX1-SW2 (Skipped)
    Rule-3: The inter-switch-link Timers should be consistent across VSX peers (Passed)
    Rule-4: The Keep-Alive Timers should be consistent across VSX peers (Passed)
    Rule-5: Active-Gateway configurations(IP, MAC and VRF) should be consistent across the VSX peers (Passed)
    Rule-6: The Keep-Alive UDP port should be consistent across VSX peers (Passed)
    Rule-7: The link-up-delay-timer should be consistent across VSX peers (Passed)
    Rule-8: The VSX System-MAC should be consistent across VSX peers (Passed)
    Rule-9: The VSX device roles should be consistent across VSX peers (Passed)
    Rule-10: VSX active-forwarding configurations should be consistent across the VSX peers (Passed)
    =============== SKIP REASONS ===============
    Rule-1: No MCLAGs are configured on VSX1-SW1
    Rule-1: No MCLAGs are configured on VSX1-SW2
    Rule-2: No MCLAGs are configured on VSX1-SW1
    Rule-2: No MCLAGs are configured on VSX1-SW2
    As you can see there is even a "skip reasons" table, which is missing on your device (or you didn't paste the whole output from your device).
    For me "skipped" means that for some reason the validation was not performed – not failed, but not validated.
    I have tried to change the VSX system mac and the configmate result was "skipped" during synchronization:
    VSX1-SW2(config)# sh vsx brief
    ISL State                              : In-Sync
    Device State                           : Sync-Secondary-Linkup-Delay
    Keepalive State                        : Keepalive-Init
    Device Role                            : secondary
    Number of Multi-chassis LAG interfaces : 0
    After few seconds the state was changed to "peer-established" and the configmate result was fine again:
    ISL State                              : In-Sync
    Device State                           : Peer-Established
    If the VSX status on your cluster looks ok and the device state on both nodes is "Peer-Established"  and there are no VSX issues, I will advise you to update the FW of your device to a newer, current version.
    Stanislav Naydenov
  • 3.  RE: vsx-configmate command inconstancies
    Posted Jun 29, 2021 05:19 PM
    Ok thanks,
    The problem seems to be similar to the command not executed issue - although your right, following an upgrade it seems to be working. We're going to try the rest of the switches and see.
    Andy Partridge
  • 4.  RE: vsx-configmate command inconstancies
    MVP GURU
    Posted Jul 03, 2021 01:17 PM
    Just for reference, on a VSX of Aruba 8320 (running ArubaOS-CX 10.05.0021 with VSX LAGs configured) and once in config mode on the Primary:
    vsx-1(config)# vsx-configmate
    Rule-1: The allowed VLAN list for ISL port must match that in config for MCLAG in vsx-1 (Passed)
    Rule-1: The allowed VLAN list for ISL port must match that in config for MCLAG in vsx-2 (Passed)
    Rule-2: The native VLAN must also be part of allowed VLAN list for a MCLAG in vsx-1 (Passed)
    Rule-2: The native VLAN must also be part of allowed VLAN list for a MCLAG in vsx-2 (Passed)
    Davide Poletto
