Yes, you must have 3 IP addresses for the same SVI,
- SVI IP address for the primary
- SVI IP address for the secondary
- active-gateway (virtual) IP address - shared
The active-gateway MAC address is shared (same on both).
For example on interface vlan 5:
Primary: interface vlan 5 vsx-sync active-gateways description BMS ip address 172.22.16.2/24 active-gateway ip mac 00:00:00:00:00:05 active-gateway ip 172.22.16.1
Secondaryinterface vlan 5 description BMS ip address 172.22.16.3/24As you correctly have, vsx-sync will synchronize the active gateway configuration from primary to secondary.
The reason you need these two IP addresses is because the routing plane on both devises is independent.
Ruben Iglesias
Original Message:
Sent: Jun 11, 2021 05:06 PM
Subject: VSX Protocol configuration on HP Aruba 8360
Hi there
I have two HP Aruba-8360 and I configured VSX on both. As you can see in the topology diagram one is primary and other one is secondary.
On Primary I have Multiple VLANs, Interface vlans and DHCP Pool for corresponding vlans. And on secondary using " VSX-SYNC '' I got vlans on my secondary switch but was unable to get SVI for corresponding vlans.
My question is :
Is it essential that we have different ip addresses in SVI on both primary and secondary?. Like for example I have
On Primary HP Aruba-8360
interface vlan 5
description BMS
ip address 172.22.x.x/24
active-gateway ip 172.22.x.x
interface vlan 6
description Metering
active-gateway ip mac 00:00:00:00:00:06
So On Secondary HP Aruba-8360
Should I have different ip address for interface vlan 5 and 6. I know we can keep the active-gateway the same on both switches but I'm not sure about IP Address for SVI.
And how I can sync primary interface vlan 5 and 6 on secondary switch using VSX Protocol in HP-Aruba 8360.
The content of this email is considered privileged. If you are not its intended recipient, please notify the sender and delete all copies immediately.
