Wall identification with VisualRF
  • 1.  Wall identification with VisualRF
    Posted May 20, 2015 10:33 AM
    Have looked in both offline and online versions of VisualRF...
    In either version, is there a method to automate the delineation of walls?
    This seems like it should be possible.
    Unfortunately, whenever we receive blueprint updates, we just receive PDFs. (Not rasterized PDFs btw)
    It seems like Aruba gears VRF to work with CAD/DMG files.
    Can anyone confirm that with CAD or DMGs, the wall material specifying doesn't have to be done over and over?
  • 2.  RE: Wall identification with VisualRF
    Posted May 20, 2015 10:34 AM
    Unfortunately, there is not a way to automatically detect walls.  They have to be drawn on all diagrams.
  • 3.  RE: Wall identification with VisualRF
    Posted May 20, 2015 10:36 AM
    Thank you Colin... can you confirm that to be the case for CAD / DMG files as well?
  • 4.  RE: Wall identification with VisualRF
    Posted May 20, 2015 10:37 AM
    the.sleeper
    It is the same with CAD drawings, as well.
