Wall or Ceiling Mount?
  • 1.  Wall or Ceiling Mount?
    Posted Sep 26, 2012 11:01 AM
    We are mounting AP 105's and have been debating wall mount vs ceiling mount options.  It sounds like ceiling mount is the preferred method.  Does anyone know if this is the case and if so what the advantages/disadvantages are?
  • 2.  RE: Wall or Ceiling Mount?
    Posted Sep 26, 2012 11:39 AM
    Most of the RF on an AP105 is directed out the face and very little comes out the back, so it is optimal to mount it on the ceiling.  If you want to mount on the wall, please ensure that the face of the AP105 is pointed to where you want coverage.
  • 3.  RE: Wall or Ceiling Mount?
    Posted Sep 26, 2012 01:36 PM
    How to mount AP92 which has external antennas?
  • 4.  RE: Wall or Ceiling Mount?
    Posted Sep 26, 2012 01:50 PM
    You can mount the ap 92s any way you would like. How you mount the antennas is what is important.
  • 5.  RE: Wall or Ceiling Mount?
    Posted Sep 26, 2012 01:56 PM
    What would be the position of antennas if we want to throw the signals in specific direction?
  • 6.  RE: Wall or Ceiling Mount?
    Posted Sep 26, 2012 02:01 PM
    Which antennas do you have, and what do you have to cover?
  • 7.  RE: Wall or Ceiling Mount?
    Posted Sep 26, 2012 02:02 PM
    Thanks for the information.  Assuming the ceiling is 9 or 10 ft high any idea how wide the coverage would be?
  • 8.  RE: Wall or Ceiling Mount?
    Posted Sep 26, 2012 04:30 PM
    You can expect very good coverage 30 feet radius either side, which is how you would deploy for a standard office deployment.  If it is open space you can expect even more.   You should have no problems deploying this AP on the ceiling.
  • 9.  RE: Wall or Ceiling Mount?
    Posted Sep 26, 2012 11:59 PM
    I'm having AP-ANT-1BP and i want to cover corridor and room attached with corridor
  • 10.  RE: Wall or Ceiling Mount?
    Posted Sep 27, 2012 12:34 AM
    I would just put the antenna vertical and measure the coverage.
    The antenna datasheet/pattern is here:  http://www.arubanetworks.com/pdf/products/ap-ant-1b_ss.pdf
    Please also see how to measure antenna coverage here:  http://community.arubanetworks.com/t5/Technology-Blog/Plan-amp-Survey-an-Outdoor-Network-10-Min-Outdoor-Network/ba-p/46296
  • 11.  RE: Wall or Ceiling Mount?
    Posted Oct 02, 2012 02:10 AM
    Thank you for your valuable information
