Walled Garden for Captive Portal
  • 1.  Walled Garden for Captive Portal
    Posted May 22, 2018 06:52 AM
    Hi all. Having some issues trying to whitelist Microsoft Azure login pages. I notice in recent version of the Instant firmware the option in the GUI for Walled Garden has disapeared. This used to be in the 'Security' Tab. I have tried using the following config in the CLI as per the user guide wlan walled-garden white-list login.microsoftonline.com white-list *.aadcdn.microsoftonline-p.com I have enabled the auto white-list of the Captive portal settings also, no luck Any ideas? I I feel like I am missing something obvious cheers Nick
  • 2.  RE: Walled Garden for Captive Portal
  • 3.  RE: Walled Garden for Captive Portal
    Posted May 29, 2018 09:27 AM
    put the walled garden entries in the the pre-auth ACL instead.
