Want to assign IPs from Controller
  • 1.  Want to assign IPs from Controller
    Posted Apr 06, 2012 07:46 AM
    I am new to MSR2000, i want to configure my MSR2000 that vlan created in MSR2000 can get ip from Aruba Controller's VLAN.
    Controller VLAN address is 192.168.40.1
    1st the default vlan 1 created in MSR and when i connect cotroller to MSR port and trying to connect with MSR BSSID i got access to controller after that.
    2nd i created Vlan 40 in my MSR1and in IPV4 tab i used only DHCP relay option 82 and uses Controllers Van ip 192.168.40.1,
    now going to BSS and created new id named TEST on radio 0 bss 6 and in IPV4 tab i inserted ip 192.168.40.1 in dhcp  rely option 82.
    When i connected to BSS "Test" not get any ip scheme form controller.
    Please help me, regards,
    Faisal
  • 2.  RE: Want to assign IPs from Controller
    Posted Apr 06, 2012 02:31 PM
    Faisal,
    Have you added the BSS "TEST" into VLAN40 by setting access Vlan40 under the BSS?
    The reason VLAN 1 works is because the BSS has been added into VLAN1 by default.
    Best,
    Xu
  • 3.  RE: Want to assign IPs from Controller
    Posted Apr 07, 2012 01:22 AM
    Xu,
    Thanks for reply, I already added BSS "TEST" in Vlan 40 by setting access Vlan40 under the BSS.
    I copied same configuration of VLAN 1 to Vlan 40+ BSS .
    Faisal
  • 4.  RE: Want to assign IPs from Controller
    Posted Apr 09, 2012 11:58 AM
    Can you post the configuration?
    Xu
  • 5.  RE: Want to assign IPs from Controller
    Posted Apr 10, 2012 03:55 AM
    All Config attached in docx format. please review and solve my porblem
    Attachment(s)
    docx
    MSR1 & 2 Configs.docx   450 KB 1 version
  • 6.  RE: Want to assign IPs from Controller
    Posted Jun 17, 2012 01:28 PM
    Faisal,
    Can you ping the controller's IPs on VLAN 20 and 40 from the command line of MSR1 and MSR2?
