want to know about Aruba Central log retain duration for WiFi
  • 1.  want to know about Aruba Central log retain duration for WiFi
    Posted 11 hours ago
    want to know about Aruba Central log retain duration for WiFi, customer wants logs for 1 year duration, do i able to get this with Aruba Central? or i need to take Aruba Clearpass.
  • 2.  RE: want to know about Aruba Central log retain duration for WiFi
    Posted 11 hours ago
    Central logs are retained for 90 days.
  • 3.  RE: want to know about Aruba Central log retain duration for WiFi
    Posted 8 hours ago
    It depends what log you want to retain, but ClearPass is an authentication server and not a log collector or retainer.
    In most cases, if you want long and reliable log storage, you would send logs to a SIEM or other log collector. You can configure your controllers or APs to send syslog, ClearPass as well. For Central you probably will need to collect those through the streaming API.
