Want to set up a wired connection with cisco switch. Anyone have a sample config for both sides?
  • 1.  Want to set up a wired connection with cisco switch. Anyone have a sample config for both sides?
    Posted Mar 18, 2015 11:42 PM
    Want to set up a wired connection with cisco 3750  switch. Anyone have a sample config for both Aruba and cisco sides?
  • 2.  RE: Want to set up a wired connection with cisco switch. Anyone have a sample config for both sides?
    Posted Mar 18, 2015 11:53 PM
  • 3.  RE: Want to set up a wired connection with cisco switch. Anyone have a sample config for both sides?
    Posted Mar 19, 2015 12:15 AM
    @tarnold wrote:
    https://ase.arubanetworks.com/solutions/id/93
    Will this only work with ClearPass? I want to use DHCP from the controller.  Does the cisco switch and Aruba controller need to be in trunk or access mode?
  • 4.  RE: Want to set up a wired connection with cisco switch. Anyone have a sample config for both sides?
    Posted Mar 19, 2015 12:18 AM
    are you trying to do .1x, or are you just looking to put a controller in a wired switch
  • 5.  RE: Want to set up a wired connection with cisco switch. Anyone have a sample config for both sides?
    Posted Mar 19, 2015 12:30 AM
    Not looking to use .1x. I want to connect a 7240 controller with a ciso 3750 switch and have wired customers from the switch obtain an ip address from dhcp on the controller. Thanks
  • 6.  RE: Want to set up a wired connection with cisco switch. Anyone have a sample config for both sides?
    Posted Mar 19, 2015 12:56 AM
    jeffgraham88,
    Maybe you can describe further in detail what you are trying to do.  Connecting a switch to a physical port on a controller is routine.  Creating a DHCP pool on the controller for that subnet and enabling it so that it gives out addresses is also routine from a switching perspective.  If you connect a 3750 with other switching devices, the configuration is the same on both the controller and the 3750.  Is there something specific that you are having difficulty with?
  • 7.  RE: Want to set up a wired connection with cisco switch. Anyone have a sample config for both sides?
    Posted Mar 19, 2015 12:10 AM
  • 8.  RE: Want to set up a wired connection with cisco switch. Anyone have a sample config for both sides?
    Posted Mar 19, 2015 09:35 AM
    This depends on the availabilty you need. If all of you hardwarre is in the same VLAN then access is what you need. If your radius is in lets say a management vlan and you clients live in a client VLAN then in order for them to talk to the radius for authentication you will need the ports to be trunked.
