I want to upgrade 7205 controller OS from 8.3.0.3 to 8.4.X.X. Both Controller in VRRP fro redudency.
For upgrade OS i need to upgrade both controller one by one or if I upgrade Primary it will automatically upgrade Secondary controller OS.
Please suggest.
Also suggest what are the stable version after 8.3.X.X.
Thanks in Advance.
I would recommend to first update the Mobililty Master, and after that the Mobility Controller Cluster. You can update it by one-by-one or a cluster upgrade.
8.3.0.8 is the latest conservative release.
8.5.0.2 is the latest standard release.
