WAP Limit to 100 RAP's on 3600 using central licensing?
  • 1.  WAP Limit to 100 RAP's on 3600 using central licensing?
    Posted Dec 29, 2015 04:46 AM
    Hi
    I am using a 3600 controller with a 3600 master-standby and 3200 local, I am using all my WAP's in RAP mode with central licensing, I have 161 AP licenses and using 100 on the master and 59 on the local but I can no longer add any more RAP's?
  • 2.  RE: WAP Limit to 100 RAP's on 3600 using central licensing?
    Posted Dec 29, 2015 06:31 AM
    On the respective controller that you are trying to terminate the new RAP on, is there enough space in the NAT pool?
  • 3.  RE: WAP Limit to 100 RAP's on 3600 using central licensing?
    Posted Dec 29, 2015 07:14 AM
    Hi
    It looks like the internal AP IP range is limited to 100, where can I amend this please?
    Many thanks
  • 4.  RE: WAP Limit to 100 RAP's on 3600 using central licensing?
    Posted Dec 29, 2015 07:31 AM
    Do a 'show run | include pool' and you should see you pool that has been configured.  I'm guessing that it only has space for 100 addresses.  If that is actually the issue, then just increase it a bit.
  • 5.  RE: WAP Limit to 100 RAP's on 3600 using central licensing?
    Posted Dec 29, 2015 07:38 AM
    Hi can I do this from the console GUI? Will it affect the current AP's if I change the IP range?
    Yes the RAP's are limited to 100 IP's!
    Many thanks
  • 6.  RE: WAP Limit to 100 RAP's on 3600 using central licensing?
    Posted Dec 29, 2015 08:08 AM
    If all you are doing is extending the current range, then it should be fine, however I don't know for certain so proceed with caution.
    I don't have a controller to hand right now to check for you, but it should be somewhere under Configuration --> Advanced --> VPN services.
  • 7.  RE: WAP Limit to 100 RAP's on 3600 using central licensing?
    Posted Dec 29, 2015 09:27 AM
    That's great,
    Many thanks for your help!
