Warning when trying to change some features on ARM
  • 1.  Warning when trying to change some features on ARM
    Posted Feb 28, 2020 02:16 PM
    Warning: If there is an entry for a radio in 'ap spectrum local-override' profile on the local controller that terminates the AP, that entry will override the mode selection in the radio profile.
    Im getting this warning everytime i try to change something like:  Use 802.11h 802.11d on 802.11g and 802.11a
    Whats that? someone can explain in to me? maybe im just not getting it because limited english understanding.
  • 2.  RE: Warning when trying to change some features on ARM
    MVP GURU
    Posted Feb 28, 2020 02:25 PM
    Its just warning you that the change will not effect an AP if it has AP specific configuration. The AP specific configuration will be used over the ap-group config.
  • 3.  RE: Warning when trying to change some features on ARM
    MVP EXPERT
    Its just an informational message you don't have any spectrum override configured. You can ignore it.
  • 4.  RE: Warning when trying to change some features on ARM
    Posted Feb 28, 2020 02:48 PM
    Thank you 2
