Wired Intelligent Edge
WC 16.11.3 - not authorised to run this command
  • 1.  WC 16.11.3 - not authorised to run this command
    Posted Jan 07, 2022 09:31 AM
    Hi
    Found something strange sincew i moved my 2930 switches to the 16.11 branch.
    Switches configured to auth against tacacs via clearpass
    clearpass 6.10.2
    switch WC.16.13.03
    I normally log on to my switches and jsut leave a console logged on. Using 16.10, could be connected for days and things still worked. With 16.11, although command prompt is there, now when ever i try executing a copmmand, I get a "not authorised to run this command" message.
    Logging out and back in and everything is o.k. again, but config hasnt changed and never did trhis before. Granted something is timing out but what ?
    Rgds
    Alex
    Alex Sharaz
  • 2.  RE: WC 16.11.3 - not authorised to run this command
    Posted Jan 07, 2022 11:55 AM
    Is the switch also configured to perform command authorization via TACACS in addition to access control?
    Do you see anything TACACS accounting on the ClearPass side?
