Network Management
WDS Airwave
  • 1.  WDS Airwave
    Posted Mar 04, 2013 06:16 AM
    I have a problem with the encryption command 'user WDSUser NTHash 7' of WDS.At the moment I have a template with many AP, in the template I created the variable conditional WDS to client to master or backup.
    When I pass the AP monitor to manage appears Mismatched  as WDSUser besause the user password does not match.
    I tried to put a incriptacion of 0 but it changes and encrypts it, but I also tested the AP <ignore_and_do_not_push> but the AP shown mismatched with the current command.
    How I can solve this issue?
    Thank you very much
    Regards
  • 2.  RE: WDS Airwave
    Posted Mar 04, 2013 01:43 PM
    I suggest opening a support case and provide the following details:.
    -The snippet of the template showing how you're trying to use the ignore flag
    -The config audit showing the desired versus the actual
