We are trying to separate mounting bracket from the Aruba AP105s. Do they have a special tool %3F
  • 1.  We are trying to separate mounting bracket from the Aruba AP105s. Do they have a special tool %3F
    Posted Mar 05, 2014 12:35 PM
    I have 60 aruba wireless access points #105 and many times I have to take them down and  separate the mounting bracket from the AP.  There is a square hole on the side that you stick in a small screw driver or a hex screw.  Then press down to depress the plastic toggle to release it from the mounted bracket.
    We are having a very difficult time separating them.  Is there a tool we can purchase to do this more easily?  It has taken us 2 hours to separate 4 APs.
    Please let me know and thank you.
    You can also send me the answer to my email address, ychan@gcschool.org
  • 2.  RE: We are trying to separate mounting bracket from the Aruba AP105s. Do they have a special tool %3F
    Posted Mar 05, 2014 12:38 PM
    I've had luck using a bit extension attachment for a screwdriver like the one included in this set.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16899261024
  • 3.  RE: We are trying to separate mounting bracket from the Aruba AP105s. Do they have a special tool %3F
    Posted Mar 05, 2014 01:57 PM
    I use my car key which seems to work quite well.
    :smileyhappy:
  • 4.  RE: We are trying to separate mounting bracket from the Aruba AP105s. Do they have a special tool %3F
    Posted Mar 17, 2014 12:08 AM
    I've had great luck using a heavy duty zip-tie. Just fold it in half. If it doesn't work at first, turn 90 degrees. For the low profile mounts, it's much easier on the knuckles than tool.
  • 5.  RE: We are trying to separate mounting bracket from the Aruba AP105s. Do they have a special tool %3F
    Posted Mar 17, 2014 02:28 AM
    I had tried using metal chopstick - those japanese thin to thick kind. :smileyvery-happy:
