Comware
Unable to access comware switch via ssh, telnet or Console.
  • 1.  Unable to access comware switch via ssh, telnet or Console.
    Posted Aug 19, 2022 04:51 AM
    We already rebooted the switch but this issue was still there.
    • We already preform factory default to this switch. then we are able to logon to the switch
    • Then we restore the previous backup, then again we are unable to access via SSH,TELNET & Console
    • We are suspect when we running NTP Synchronization and Password Control Policy features both are together this issue is occur.(Because try to logon to the switch by disabling both NTP synchronization & Password control policy features we can access switch without any issue)
    • We need to clarify If there is any firmware related issue/bug in current comware version of the Switch?
    Please help me to resolve this issue
    Switch Model: HP 5130-24G-4SFP+EI,
    Part No: JG932A.
    current version (7.1.045, Release 3106)
    DhanushkaH
  • 2.  RE: Unable to access comware switch via ssh, telnet or Console.
    Posted Sep 02, 2022 03:42 AM
    I appreciate the information and advice you have shared. I will try to figure it out for more.
  • 3.  RE: Unable to access comware switch via ssh, telnet or Console.
    Posted Sep 14, 2022 05:53 AM
    If you posted some config related to vty, aux lines and ssh would probably help understand your issue
