We have a 3600 controller. 2 SSID enabled on the Access points.
  • 1.  We have a 3600 controller. 2 SSID enabled on the Access points.
    Posted Feb 05, 2014 11:14 PM
    On one of the SSID the email is not syncing with the gmail server through IPAD. And I am not able to to Airplay with apple tv. What could be wrong?
    #3600
  • 2.  RE: We have a 3600 controller. 2 SSID enabled on the Access points.
    MVP EXPERT
    Posted Feb 06, 2014 02:22 AM
    There's quite a few items you can check and if you have some further information this will help :)
    - Are these SSID"s using the same VLAN? Is the routing to/from these VLAN's correct?
    - Is anything being denied by the firewall/3-way hand shake completing? "show datapathsession | include xx.xx.xx.xx" will show you this. Look for a D or Y flag if there is usses?
    - Is there any difference in the assigned roles? "show rights xxx" where xxxx is the role assigned to the iPad.
    - Is there any upstream firewalls or such blocking the Gmail traffic?
    - What ArubaOS are you using As AirPlay was only included in the later releases.
    If you want to attach a copy of your configuration we can review the settings
    Rgds,
  • 3.  RE: We have a 3600 controller. 2 SSID enabled on the Access points.
    Posted Feb 06, 2014 02:28 AM
    Check the user role and policies applied on that role.
  • 4.  RE: We have a 3600 controller. 2 SSID enabled on the Access points.
    Posted Feb 08, 2014 01:39 PM
    Thaz, were you able to get your problem resolved with the feedback from above?
  • 5.  RE: We have a 3600 controller. 2 SSID enabled on the Access points.
    Posted Oct 29, 2014 07:48 AM
    Yes I was able to solvve it.
