Wired Intelligent Edge
WEB Access controller 7210
  • 1.  WEB Access controller 7210
    Posted Jul 05, 2018 03:14 PM
    What would I check in cli to see if WEB access is enabled. The network firewall would need port 443 and 4343 open correct
  • 2.  RE: WEB Access controller 7210
    Posted Jul 11, 2018 06:58 PM
    Hello Legwhite!
    For WebUI Access you can connect via HTTP on TCP ports 80 and 8888, or via HTTPS on TCP ports 443 and 4343.
    A quick way to validate that you've enabled HTTPS is with the command:
    show web-server profile
    You can configure these options via CLI with commands in the 'configure terminal' -> 'web-server profile' context, allowing you to change authentication types, SSL/TLS protocols, and more.
    Hope this helps!
