Web Category
  • 1.  Web Category
    Posted Jul 05, 2015 01:09 PM
    I was wondering if this will remain free on instant AP? At least its looks like free right now.
    Also there is application feature  which its free right now and i bealive it meant to be free but just checking.
    Cheers
    Carlos
  • 2.  RE: Web Category
    Posted Jul 05, 2015 01:13 PM
    There is a SKU for it so I would assume it will not.
    Tim
  • 3.  RE: Web Category
    Posted Jul 05, 2015 01:21 PM
    Welli can see it.
    But if its per AP that looks really expensive (it would be cheaper and better having a small UTM) Just saying...
    It would have been cool if it was free :P or maybe included in the next day support fee and maybe adding some dollars to it.
    Cheers
    Carlos
  • 4.  RE: Web Category
    Posted Jul 05, 2015 01:25 PM
    It's included in the Aruba Central license. The pricing is right in line with other web filtering services.
    Tim
  • 5.  RE: Web Category
    Posted Jul 05, 2015 01:32 PM
    I was compairing it to a UTM not a webfilter service only like openDNS which is extremely expensive.
    Anyways if you have arubacentral and its included in there then thats looks just fine(if you got aruba central)
    Thanks for the info
    I wonder when  it will stop being free?
    Cheers
    Carlos
  • 6.  RE: Web Category
    Posted May 02, 2016 10:36 AM
    I care too, will web category and application filtering remain free, or will be required to license?
    Is this an OpenDNS-based service?
  • 7.  RE: Web Category
    Posted May 02, 2016 10:38 AM
    Instant requires a license for WebCC if you do not already have an Aruba Central subscription.
    AOS will require a license in 6.5 for WebCC functionality. It has been in beta in past releases.
