Web Content Classification... Anyone have it working?
  • 1.  Web Content Classification... Anyone have it working?
    Posted Sep 15, 2014 02:35 PM
    I tried to get it up and working but am having issues with connecting to the URL Cloud Lookup server..  Has anyone had success with this, do I need to allow something specifically to make this work?
    #show web-cc status
    Web Content Classification Status
    Service Status
    Web Content Classification enabled : Yes
    DNS/Name Server configured : Yes
    URL Cloud lookup server reachable : No
  • 2.  RE: Web Content Classification... Anyone have it working?
    Posted Sep 15, 2014 02:36 PM
    Mine is working. Did you enable it in both the global firewall settings and in your user-roles?
  • 3.  RE: Web Content Classification... Anyone have it working?
    Posted Sep 15, 2014 02:39 PM
    Yes I belive I have both enabled, from  #show web-cc status.. it appears I can not connect to the classification servers of Aruba..  What do I need to do to allow this?
  • 4.  RE: Web Content Classification... Anyone have it working?
    Posted Sep 15, 2014 02:42 PM
    Is your management IP public? If not, is it NATed?
  • 5.  RE: Web Content Classification... Anyone have it working?
    Posted Sep 15, 2014 05:26 PM
    managment IP is not public, it is behind a NAT.
    I can succesfully ping outside domains.
    ping www.yahoo.com
    Press 'q' to abort.
    Sending 5, 92-byte ICMP Echos to 98.138.253.109, timeout is 2 seconds:
  • 6.  RE: Web Content Classification... Anyone have it working?
    Posted Feb 01, 2016 10:41 AM
    Did you get an answer for this ?
    I´ve got the exact same issue
    Service                               Status
    Some info from the log:
    Feb 1 16:55:14 <web_cc 354001>  <ERRS> |web_cc|  aruba.brightcloud.com:Temporary failure in name resolutionresolve, bca_net.c:383
    I can ping google.com from the cli of the controller without any issues.
  • 7.  RE: Web Content Classification... Anyone have it working?
    Posted Feb 01, 2016 11:25 AM
    THe controller gets its updates from aruba.brightcloud.com
    And it seems like it is not able to.
    Can you try pinging that ?
  • 8.  RE: Web Content Classification... Anyone have it working?
    Posted Feb 01, 2016 11:40 AM
    I get a domain lookup and see the IP in the terminal window but the host doen´t answer to ping packets.
    #ping aruba.brightcloud.com
    Press 'q' to abort.
    Sending 5, 92-byte ICMP Echos to 54.229.113.176, timeout is 2 seconds:
    Success rate is 0 percent (0/5)
    Not from my wired host either though, are you able to ping the host?
    Pinging bcap15.brightcloud.com [54.229.113.176] with 32 bytes of data&colon;
    Request timed out.
  • 9.  RE: Web Content Classification... Anyone have it working?
    Posted Feb 01, 2016 11:54 AM
    Hi thanks for the help.
    Seems a simple reboot solved the problem...
    Service                               Status
    URL Cloud lookup server reachable :   Yes
    Should have tried reboot first ofcourse...
  • 10.  RE: Web Content Classification... Anyone have it working?
    Posted May 03, 2019 05:10 AM
    Same problem here, web-cc licences uploaded and activated, web-cc feature enabled, MM was rebooted, but don't work.
    Service                               Status
    Mode :                                MM
    Port 443 is opened to aruba.brightcloud.com on the firewall, but no traffic is going there. And we checked on firewall, no dropped traffic found with this destination address.
    Firmware: 8.3.0.1 (We wouldn't like to upgrade because of the many known issues in later releases. 8.3.x is mandatory because of AP types, means AP-345)
    Any idea?
