web interface controller not reachable in vlan 101
  • 1.  web interface controller not reachable in vlan 101
    Posted Feb 22, 2021 09:52 AM
    controller running aruba 8.something (i suspect 8.6)
    Besides vlan 1, also having vlan 101 and ip address in that vlan.
    Issue is that altough controller-ip is set for vlan 101, ip and gateway are all correct for vlan 101, web mgmt interface is still only available from vlan 1.
    show web-server profile
    Web Server Configuration
    Parameter                                          Value
    Cipher Suite Strength                              high
    SSL/TLS Protocol Config                            tlsv1 tlsv1.1 tlsv1.2
    Switch Certificate                                 default
    Captive Portal Certificate                         fc-wildc-deme-group
    IDP Certificate                                    default
    Management user's WebUI access method              username/password
    User absolute session timeout <30-3600> (seconds)  0
    User session timeout <30-3600> (seconds)           900
    Maximum supported concurrent clients <25-320>      75
    Enable WebUI access on HTTPS port (443)            false
    Enable bypass captive portal landing page          false
    Exclude Security Headers from HTTP Response        false
    VIA client-cert port number                        8085
    show firewall-cp internal | include 443
    ipv4        any                     6         443         443       Permit          272      cpbwc-ipv4-http
    ipv6        any                     6         443         443       Permit          0        cpbwc-ipv6-http
    show web-server statistics
    Web Server(Non-Captive Portal) Statistics:
    Current Request Rate:            1 Req/Sec
    Current Traffic Rate:            1 KB/Sec
    Busy Connection Slots:           1
    Available Connection Slots:      74
    Total Requests Since Up Time:    7941
    Total Traffic Since Up Time:     87737 KB
    Avg. Request Rate Since Up Time: 0 Req/Sec
    Avg. Traffic Rate Since Up Time: 369 Bytes/Sec
    Server Scoreboard ________________________________________W__________________________________
    Scoreboard Key: _ - Waiting for Connection, s - Starting up
                    R - Reading Request, W - Sending Reply
                    K - Keepalive, D - DNS Lookup
                    C - Closing connection, L - Logging
                    G - Gracefully finishing, I - Idle cleanup of worker
                    . - Open slot with no current process
    Web Server(Captive Portal) Statistics:
    Accepted Connections: 1
    Active Connections: 1
    Handled Connections: 1
    Idle Connections: 0
    Number of Requests: 1
    Already restarted httpd.  Nothing pops up in the logs.  Issue remains.  I can ping the interface in vlan 101 btw.  Anybody an idea what i'm missing?
    Peter Nobels
  • 2.  RE: web interface controller not reachable in vlan 101
    Posted Feb 22, 2021 02:24 PM
    What controller model is this ?
    Is all the physical interface of the controller part of VLAN 101 ?
    Kapildev Erampu
    PreSales Consultant
    Aruba, a Hewlett Packard Enterprise company
    Sydney, Australia.
    Any opinions expressed here are solely my own and not necessarily that of HPE
  • 3.  RE: web interface controller not reachable in vlan 101
    Posted Feb 23, 2021 02:40 AM
    7010 controller.  The vlans are all part of a trunk.  Vlan 101 is native vlan.
    Peter Nobels
  • 4.  RE: web interface controller not reachable in vlan 101
    Posted Feb 24, 2021 08:01 AM
    Can you even ping it on the ip address in VLAN 101
