Web Interface to the controller stopped but can get to it via SSH
This thread has been viewed 95 times
  • 1.  Web Interface to the controller stopped but can get to it via SSH
    Posted Apr 02, 2015 07:00 AM
    This morning I tried to access the controller (6000 with M3 card), but I could not open the web interface to it. I am able to ping it and SSH to it. We are running 6.3.1.2 AOS. Is there a service(s) to restart without restarting the whole controller?
  • 2.  RE: Web Interface to the controller stopped but can get to it via SSH
    Posted Apr 02, 2015 07:24 AM
    process restart httpd
    Tim
  • 3.  RE: Web Interface to the controller stopped but can get to it via SSH
    Posted Apr 02, 2015 08:15 AM
    Thanks Tim.
    TAC called back and found that for some reason the Enable WebUI access on HTTPS port (443) was set to false. TAC looked and did not see why it changed to false since no configuration change was made.
  • 4.  RE: Web Interface to the controller stopped but can get to it via SSH
    Posted Nov 19, 2019 03:09 AM
    I know i'ts an old post... could you please exlpain hot to enable webui access on https port?
  • 5.  RE: Web Interface to the controller stopped but can get to it via SSH
    MVP EXPERT
    Posted Nov 19, 2019 03:55 AM
    By default the Web interface is enabled via TCP4343, if you need to change this to HTTPS (TCP443) use the following:
    (Aruba7030) *[mynode] (config) #web-server profile
    (Aruba7030) *[mynode] (Web Server Configuration) #
    (Aruba7030) *[mynode] (Web Server Configuration) #web-https-port-443
  • 6.  RE: Web Interface to the controller stopped but can get to it via SSH
    Posted Nov 19, 2019 04:11 AM
    thnx Craig for the quick answer
    but my problem remains.
    I can't get to the webui of my Dell  powerconnect w3200 controller.
    I can get to the controller through ssh
  • 7.  RE: Web Interface to the controller stopped but can get to it via SSH
    Posted Nov 19, 2019 04:18 AM
    Might be high cpu usage?
    did u enable some extra logging on the controller? (try to disable them)
    please send us cpu usage output from cli.
  • 8.  RE: Web Interface to the controller stopped but can get to it via SSH
    Posted Nov 19, 2019 04:30 AM
    (Master-Aruba) #show cpuload
    user 1.2%, system 0.7%, idle 98.1%
    it looks ok
    I was able to connect to the webui using firefox but I didn't login using the same user used throuch ssh
    thanks a lot
    Web Server Statistics:
    Current Request Rate: 1 Req/Sec
    Current Traffic Rate: 0 KB/Sec
    Busy Connection Slots: 1
    Available Connection Slots: 24
    Total Requests Since Up Time: 1
    Total Traffic Since Up Time: 0 KB
    Avg. Request Rate Since Up Time: 0 Req/Sec
    Avg. Traffic Rate Since Up Time: 0 Bytes/Sec
    Server Scoreboard _W_______________________
  • 9.  RE: Web Interface to the controller stopped but can get to it via SSH
    Posted Nov 19, 2019 04:55 AM
    after several minutes I was able to see the login :)
    I'll try to login again and wait...
    the controller is working perfectly we have about 80 clients
  • 10.  RE: Web Interface to the controller stopped but can get to it via SSH
    Posted Nov 19, 2019 07:33 AM
    controller is working but no webui. I think I'll restore a previous config
  • 11.  RE: Web Interface to the controller stopped but can get to it via SSH
    Posted Nov 26, 2019 08:16 PM
    Hi guys,
    Do you have advise how to solve the error 403 for webui access?
    Forbidden
    You don't have permission to access / on this server.
    Additionally, a 403 Forbidden error was encountered while trying to use an ErrorDocument to handle the request.
    It was a newly restore OS to the 7005 controller.
    Thank you.
  • 12.  RE: Web Interface to the controller stopped but can get to it via SSH
    Posted Nov 27, 2019 02:22 AM
    Personally I gave up...
    No way to figure it out.
    but our w3200 controller works and I can get to it using ssh.
    I'll try with a firmware upgrade on a closing day.
