Just had to read the RIGHT Manual on the RIGHT Website (H3C)....
The only thing I have forgotten to configure was:
authorization-attribute level 3
The service-type is telnet.
I found the description for configuring the Web interface in the H3C S5120-EI Series Ethernet Switches
Fundamentals Configuration Guide: http://www.h3c.com.hk/Technical_Support___Documents/Technical_Documents/Switches/H3C_S5120_Series_Switches/Configuration/Operation_Manual/H3C_S5120-EI_CG-Release_2210-6W100/01/ on page 61 (Chapter: Web login).
Configuration example for http access:
# Log in to the device via the console port and configure the IP address of VLAN 1 of the device. VLAN
1 is the default VLAN.
<Sysname> system-view
[Sysname] interface vlan-interface 1
[Sysname-VLAN-interface1] ip address 192.168.0.58 255.255.255.0
[Sysname-VLAN-interface1] quit
# Create a local user named admin, and set the password to admin for the user. Specify the telnet service
type for the local user, and set the command level to 3 for this user.
[Sysname] local-user admin
[Sysname-luser-admin] service-type telnet
[Sysname-luser-admin] authorization-attribute level 3
[Sysname-luser-admin] password simple admin
That easy? YES!
P.S.:
Maybe you will have to activate the http service if it's not enabled by default:
[Sysname]ip http enable
Manfred
#Webinterface#Weblogin
