WebCC menu didn't appear under Traffic Analyzis
  • 1.  WebCC menu didn't appear under Traffic Analyzis
    Posted Apr 01, 2019 07:12 AM
    Hi Guys!
    I added and enabled WebCC licences, enabled firewall visibility, dpi and webcc under Services -> Firewall for MDs, rebooted all of MDs, and WebCC menu didn't appear under Traffic Analyzis:
    I know that the number of AP and WebCC licenses do not match, it is an order error, there will be 30 piece of AP in the system.
    OS versions:
    MM: 8.3.0.1
    MDs: 8.3.0.1
    Thanks!
  • 2.  RE: WebCC menu didn't appear under Traffic Analyzis
    Posted Apr 03, 2019 12:21 AM
    Hi SkiP,
    what do you mean by WebCC menu? Traffic Analysis is already the best place to see, what DPI tracks.
  • 3.  RE: WebCC menu didn't appear under Traffic Analyzis
    Posted Apr 03, 2019 03:54 AM
    Hi Florian,
    From AOS 8.3.0.x config guide: (page 782)
    Accessing WebCC in Dashboard
    Navigate to Dashboard > Traffic Analysis . Click the Web Content tab. The following figure shows the Web Content page:
    Figure 71 Web Content Page
    I search for this Tab under Traffic Analyzis.
  • 4.  RE: WebCC menu didn't appear under Traffic Analyzis
    Posted Apr 04, 2019 12:05 AM
    Hi SkiP,
    you are correct. It should be there. But i'm not aware of any circumstance where we would make this tab not available. If you do not have the license, you will still have the tab, but with no data.
    Have you tried a different browser?
    You are running 8.3.0.1, which is quite old, considered we are currently at 8.3.0.6. Would it be possible to upgrade to this version?
    What is the output of the commands below, on the MD:
    (wlan-controller) #show web-cc stats
    Web Content Classification Statistics
    Name                      Counter
    URL miss from sos                    14
    Database hit                          0
    Private IP addresses                 14
    Cloud lookup                          0
    Cloud response                        0
    RTU updates                           0
    DB Entries                            0
    Cache update errorcount               0
    (wlan-controller) #show web-cc status
    Web Content Classification Status
    Service                               Status
    Web Content Classification enabled :  Yes
    DNS/Name Server configured :          Yes
    URL Cloud lookup server reachable :   Yes
    Cloud lookup/update available :       Yes
    Webroot Server Connection Type :      ipv4
    Mode :                                MD - Centralized
    MM IP address :                       10.100.100.70
    BR
    Florian
  • 5.  RE: WebCC menu didn't appear under Traffic Analyzis
    Posted Apr 08, 2019 05:44 AM
    I experienced a quite lot of problems/bugs under 8.3.x.x versions, so I would like to use CR releases. In this system it is not possible because of 345 type APs. However 8.3.0.1 release notes states more few known bugs like newer 8.3.0.x releases, so I would like to stay in this version.
    I checked an other system that runs on AOS8 MMs and MDs, that runs 8.2.2.4 (newest CR release) and haven't got WebCC licences, however there isn't WebCC Tab also.
    I tried by 4 different browsers (FF, Chrome, IE, Opera), same experiences.
    It Isn't possible to enter these commands on MDs:
    (MobilityMaster) [mynode] #cd
    /md
    /md/company-hq
    /mm
    /mm/mynode
    MC1                     Alias for /md/company-hq/20:4c:03:2b:4d:3c
    MC2                     Alias for /md/company-hq/20:4c:03:2b:4e:5c
    <node-path>             Path of config node
    (MobilityMaster) [mynode] #cd MC1
    (MobilityMaster) [20:4c:03:2b:4d:3c] #mdconnect
     Redirecting to Managed Device Shell
    Last login: Mon Apr  8 10:57:43 2019 from 10.75.75.92
    (MC1) [MDC] #show web-
    web-proxy               Web proxy server information
    web-server              Display web server configuration and statistics
    (MC1) [MDC] #exit
    Exiting Managed Device Shell
    (MobilityMaster) [20:4c:03:2b:4d:3c] #cd MC2
    (MobilityMaster) [20:4c:03:2b:4e:5c] #mdconnect
    Redirecting to Managed Device Shell Last login: Mon Apr 8 03:24:45 2019 from 10.75.75.91 (MC2) [MDC] #show web- web-proxy Web proxy server information web-server Display web server configuration and statistics
  • 6.  RE: WebCC menu didn't appear under Traffic Analyzis
    Posted Apr 23, 2019 04:23 AM
    That's weird, as the commands should be there. I tested it several times.
    I would suggest opening a support ticket as the behavior, at least from my point of view, is not the normal behavior.
