WebUI PEM Certificate upload ... no prompt for key file
  • 1.  WebUI PEM Certificate upload ... no prompt for key file
    Posted Jun 17, 2019 06:44 AM
    Trynig to upload Root/Intermediate CA and WebUI cert onto an Instant cluster.
    Root/Intermediate C worked just fine
    However ...
    When trying to upload a WebUI cert. I downloaded a cert in PEM format along with a key file and generated a password ( from our PKI Service)
    When specifying a WebUI upload, you're prompted for file name, cert type X509 with file extension of .pem,.crt or .cer
    and passphrase * 2
    ... no prompt for the key file so install fails. with no key file error.
    Can't use pkcs12 as file upload tells me invalid file format
    So how am I supposed to upload a .key file ?
    Rgds
    Alex
  • 2.  RE: WebUI PEM Certificate upload ... no prompt for key file
    Posted Jun 17, 2019 06:45 AM
    Running 8.5.0 BTW
  • 3.  RE: WebUI PEM Certificate upload ... no prompt for key file
    Posted Jun 20, 2019 09:00 AM
    You will need to concatenate the key, cert, and intermediates in a single PEM file:
    -----BEGIN RSA PRIVATE KEY-----
    Proc-Type: 4,ENCRYPTED
    <your private key>
    -----END RSA PRIVATE KEY-----
    -----BEGIN CERTIFICATE-----
    <your signed certificate>
    -----END CERTIFICATE-----
    <the CA intermediate that is just above your server certificate>
    <the CA intermediate that is above the first intermediate (OPTIONAL, Only if exists)>
    Then import that one.
