Wired Intelligent Edge
last person joined: 7 hours ago
Weird MAS PoE difficulties
  • 1.  Weird MAS PoE difficulties
    Posted Dec 01, 2015 10:05 AM
    I've had this problem on another S1500 switch, but can't for the life of me figure out why.
    I have a WIFI Vlan and a default VLAN. For ports that I setup on the WIFI VLAN, I do not get POE delivered to the access point. These ports have the same POE profile. Despite this, a web gui dashboard interfaces show these as "disable" when nothing is connected, as opposed to "not drawing power"
    If I move my AP connection from a 114 port to a default port, it lights up right away.
    Here's my config:
    #show conf
    # Configuration file for ArubaOS
    # ArubaOS Version 7.4.1.0 50853
    version 7.4
    enable secret "8eb7928301522873ebe6a40451664f14df48ef0bd08f47b5a8"
    hostname "Security-Aruba"
    clock timezone EST -5
    location "Building1.floor1"
    controller config 4
    ip access-list eth validuserethacl
      permit any
    netservice svc-dhcp udp 67 68
    netservice svc-dns udp 53
    netservice svc-ftp tcp 21
    netservice svc-h323-tcp tcp 1720
    netservice svc-h323-udp udp 1718 1719
    netservice svc-http tcp 80
    netservice svc-https tcp 443
    netservice svc-icmp 1
    netservice svc-kerberos udp 88
    netservice svc-natt udp 4500
    netservice svc-ntp udp 123
    netservice svc-sip-tcp tcp 5060
    netservice svc-sip-udp udp 5060
    netservice svc-sips tcp 5061
    netservice svc-smtp tcp 25
    netservice svc-ssh tcp 22
    netservice svc-telnet tcp 23
    netservice svc-tftp udp 69
    netservice svc-vocera udp 5002
    ip access-list stateless allowall-stateless
      any any any  permit
    ip access-list stateless cplogout-stateless
      user   alias controller sys-svc-https  dst-nat 8081
    ip access-list stateless dhcp-acl-stateless
      any any svc-dhcp  permit
    ip access-list stateless dns-acl-stateless
      any any svc-dns  permit
    ip access-list stateless http-acl-stateless
      any any svc-http  permit
    ip access-list stateless https-acl-stateless
      any any svc-https  permit
    ip access-list stateless icmp-acl-stateless
      any any svc-icmp  permit
    ip access-list stateless logon-control-stateless
      any any svc-natt  permit
    ip access-list session validuser
      network 169.254.0.0 255.255.0.0 any any  deny
      any any any  permit
    user-role authenticated
    user-role denyall
    user-role denydhcp
    user-role guest
    user-role logon
    user-role preauth
    crypto ipsec transform-set default-boc-bm-transform esp-3des esp-sha-hmac
    crypto ipsec transform-set default-rap-transform esp-aes256 esp-sha-hmac
    mgmt-user admin root a7cc8a63016987ecf339c58d2ab85f015b4cc57b9a2324c089
    ntp server 10.110.138.1
    firewall disable-stateful-h323-processing
    ip domain lookup
    aaa authentication mac "default"
    aaa authentication dot1x "default"
    aaa server-group "default"
     auth-server Internal
     set role condition role value-of
    aaa profile "default"
    aaa authentication captive-portal "default"
    aaa authentication vpn "default"
    aaa authentication mgmt
    aaa authentication wired
    web-server
    aaa password-policy mgmt
    traceoptions
    probe-profile "default"
       protocol icmp
    qos-profile "default"
    policer-profile "default"
    ip-profile
       default-gateway 10.110.138.1
       controller-ip vlan 110
    mode-button
       enable factory-default
    interface-profile ospf-profile "default"
       area 0.0.0.0
    interface-profile pim-profile "default"
    interface-profile igmp-profile "default"
    stack-profile
    ipv6-profile
    activate-service-firmware
    aruba-central
    rogue-ap-containment
    interface-profile switching-profile "default"
       access-vlan 110
    interface-profile switching-profile "Upstream-profile"
       switchport-mode trunk
    interface-profile switching-profile "WIFI-profile"
       access-vlan 114
    interface-profile tunneled-node-profile "default"
    interface-profile poe-profile "default"
    interface-profile poe-profile "device-group-default"
       enable
       poe-priority high
    interface-profile poe-profile "poe-factory-initial"
       enable
    interface-profile enet-link-profile "default"
    interface-profile lldp-profile "default"
    interface-profile lldp-profile "lldp-factory-initial"
       lldp transmit
       lldp receive
       med enable
    interface-profile mstp-profile "default"
    interface-profile pvst-port-profile "default"
    vlan-profile dhcp-snooping-profile "default"
    vlan-profile mld-snooping-profile "default"
    vlan-profile igmp-snooping-profile "default"
       snooping
    vlan-profile igmp-snooping-profile "igmp-snooping-factory-initial"
       snooping
    spanning-tree
       mode mstp
    gvrp
    mstp
    lacp
    poe-management-profile slot "0"
    vlan "1"
    vlan "110"
    vlan "111"
       description "Voice"
    vlan "112"
       description "MultMedia"
    vlan "113"
       description "Sodexo"
    vlan "114"
       description "WIFI"
    vlan "115"
       description "ServerPrinter"
    interface gigabitethernet "0/0/0"
    interface gigabitethernet "0/0/1"
    interface gigabitethernet "0/0/2"
    interface gigabitethernet "0/0/3"
    interface gigabitethernet "0/0/4"
    interface gigabitethernet "0/0/5"
    interface gigabitethernet "0/0/6"
    interface gigabitethernet "0/0/7"
    interface gigabitethernet "0/0/8"
    interface gigabitethernet "0/0/9"
    interface gigabitethernet "0/0/10"
    interface gigabitethernet "0/0/11"
    interface gigabitethernet "0/1/0"
    interface vlan "110"
       ip address 10.110.138.38 255.255.255.0
    device-group ap
    interface-group gigabitethernet "default"
       apply-to ALL
    snmp-server community Zer0t0uchpr0visi0ning view ALL
    snmp-server view ALL oid-tree iso included
    snmp-server group ALLPRIV v1 read ALL notify ALL
    snmp-server group ALLPRIV v2c read ALL notify ALL
    snmp-server group ALLPRIV v3 noauth read ALL notify ALL
    snmp-server group AUTHPRIV v3 priv read ALL notify ALL
    snmp-server group AUTHNOPRIV v3 auth read ALL notify ALL
    snmp-server group Zer0t0uchpr0visi0ning v1 read ALL
    snmp-server group Zer0t0uchpr0visi0ning v2c read ALL
    snmp-server enable trap
    process monitor log
    end
    (Security-Aruba) #
  • 2.  RE: Weird MAS PoE difficulties
    Posted Dec 02, 2015 03:41 AM
    Kevets,
     On S1500-12P box, only 8 ports are PoE capable. Hence you might be seeing issue.
     You mentoned about '114 port to a default port'
     What is 114 port ?
    -Vinay
  • 3.  RE: Weird MAS PoE difficulties
    Posted Dec 02, 2015 09:01 AM
    Well I'll be damned (and highly irritated). Nowhere on the chassis does it indicate 8 powered ports or which ones. And the WebGUI has no complaint when you assign ports 8-11 to a powered profile.
    So I'm assuming it's the first 8 ports (0-7) that get PoE?
    What I meant by 114 is the VLAN assignment, which was the only difference I could see with the configuration of these ports.
    Anyway, thanks for the help!
  • 4.  RE: Weird MAS PoE difficulties
    Posted Dec 02, 2015 09:17 AM
    On all MAS switches, the ports that have an orange number are PoE capable. White numbers are not.
    Sent from Nine
  • 5.  RE: Weird MAS PoE difficulties
    Posted Dec 02, 2015 09:22 AM
  • 6.  RE: Weird MAS PoE difficulties
    Posted Dec 02, 2015 09:59 AM
    OK thanks. My bad for not reading the installation guide.
