Weird problem with IAP Roaming
  • 1.  Weird problem with IAP Roaming
    Posted Nov 06, 2018 06:18 AM
    Hi everyone!
    This is my first post but i needed to make this because i didnt found answer by myself.
    This is just annoying problem and causes confusion in users.
    Environment:
    We have problem with IAP-Cluster which is controlled by airwave 8.2.7.
    There are 3 SSID's.
    None of them uses Captive Portal.
    Issue:
    Sometime's when Client in this case laptop roam to another Access Point it pop's up:
    -302 captive portal
    -internal error, captive portal is disable
    That time connections are broke. But it won't take long to heal working.
    So what i am asking:
    Have anyone faced same kind of problem or found solution for that?
  • 2.  RE: Weird problem with IAP Roaming
    Posted Nov 06, 2018 10:42 AM
    What switches are your Instant APs connected to?  It almost looks like some of your Instant APs are connected to an untrusted port of an Aruba Controller....
  • 3.  RE: Weird problem with IAP Roaming
    Posted Nov 12, 2018 01:08 AM
    Those ap's are connected to Extreme summit switches. But there came up something else what they fixed. There was two IAP-cluster's in different vlan's with same ssid's. That i didn't knew. Now ap's are in a same cluster i guess this fixes the problem but if it still exists i'll be back.
