What am i missing? I want User + Computer authentication, NEED HELP
  • 1.  What am i missing? I want User + Computer authentication, NEED HELP
    Posted Jul 20, 2015 08:35 PM
    i thought what i have ended up setting up would be simple.
    I wanted AD user + computer account authentication.
    User auth is easy but i just cannot get the computer auth to work right.
    All i want is it to check IF the computer account exists in AD + the user authentication and its just not working.
    What should i do to set that up??
    I thought setting AD member of a group in the AD auth would do it but that didn't work and still allowed people to login no matter if the computer/phone was in AD or not.
  • 2.  RE: What am i missing? I want User + Computer authentication, NEED HELP
    Posted Jul 20, 2015 08:36 PM
    Are your clients configured for both Computer and User authentication? Do you have a rule in your enforcement that checks for both [User Authenticated] and [Machine Authenticated] TIPS roles?
  • 3.  RE: What am i missing? I want User + Computer authentication, NEED HELP
    Posted Jul 21, 2015 11:08 AM
    What do i need to do for the clients to be configured for both authentication styles?
    I am following an example for the tips checks.
    Can this be done with just the integrated IAP controller and we can just bypass clearpass?
  • 4.  RE: What am i missing? I want User + Computer authentication, NEED HELP
    Posted Jul 21, 2015 11:31 AM
    It is recommended to do it via Group Policy.
    If you want to do it manually, you would configure it in your wireless network connection profile under Advanced.
  • 5.  RE: What am i missing? I want User + Computer authentication, NEED HELP
    Posted Jul 21, 2015 11:47 AM
    i am going to ask this simply.
    What do you recommend being the quickest way to do something similar to what i am looking for?
    just checking against a AD account and IF the computer account exists in ad.
    I was hoping i wouldn't have to configure wireless profiles as the laptops in the company are all different models/ages
  • 6.  RE: What am i missing? I want User + Computer authentication, NEED HELP
    Posted Jul 21, 2015 11:51 AM
    If you want to do computer based authentication, you'll have to configure the clients. Using group policy makes this very easy to do.
    Tim
