What amount of power is needed from a POE adaptor to power an IAP
  • 1.  What amount of power is needed from a POE adaptor to power an IAP
    Posted Jul 02, 2014 06:12 AM
    Good day,
    We have a couple of IAP's that need power sopplied to them.
    Our POE switch ports are full and we are now looking at getting some POE adaptors. What is the specs needed from the POE adaptors to fire up the IAP's
  • 2.  RE: What amount of power is needed from a POE adaptor to power an IAP
    Posted Jul 02, 2014 06:26 AM
    The access point matrix here:  http://www.arubanetworks.com/pdf/products/MAT_AP.pdf will tell what POE standard (poe PD power) needs to be applied to those access points.
