Its time to move my global environment off of ver 6.3.1.5. But what is the most stable ver out there right now? I have combination of controller types.
I have been running 6.4.2.6, but I am about to upgrade to 6.4.4.9. I haven't heard anything about it being unstable, so I would guess that would be your best bet.
Is your 3xxx a 3200, 3400 or 3600? If it is a 3400 or 3600, 6.4.4.9 is the latest GA (stable) code.
Colin, what should I use across the board if I have 7200 Master and 7200/7000 with two 3200 Local Controllers?
The 3200s needs to be an XM or hopefully you upgraded the memory physically. If you have done either of those things, 6.4.4.9 is for you.
