What are best practices or tips to use a RADIUS server as authentication source for ClearPass?
  • 1.  What are best practices or tips to use a RADIUS server as authentication source for ClearPass?
    Posted Apr 18, 2016 02:59 PM
    We use Microsoft MFA for two-factor authentication (2FA). MFA can be used as a RADIUS server so I created a Service in my CPPM to use MFA as the authentication source. When I attempt to authenticate to a device now, I get the expected phone call from MFA and I enter my PIN as required for that system. MFA logs indicate I passed authentication but CPPM is showing a failed auth message. What am I missing? Are there specific vendor-specific attributes (VSAs) I need to configure for MFA to send back to CPPM?
  • 2.  RE: What are best practices or tips to use a RADIUS server as authentication source for ClearPass?
    Posted Apr 19, 2016 10:28 AM
    Any takers?
  • 3.  RE: What are best practices or tips to use a RADIUS server as authentication source for ClearPass?
    Posted Apr 19, 2016 10:53 AM
    You didn't say why the RADIUS auth was failing. Is it timing out waiting for the MFA to complete? The default timeout is only 10 seconds.
  • 4.  RE: What are best practices or tips to use a RADIUS server as authentication source for ClearPass?
    Posted Apr 19, 2016 11:07 AM
    Error Code:
    206
    Error Category:
    Authentication failure
    Error Message:
    Access denied by policy
    Alerts for this Request
    RADIUS Applied 'Reject' profile
  • 5.  RE: What are best practices or tips to use a RADIUS server as authentication source for ClearPass?
    Posted Apr 19, 2016 11:11 AM
    I also have increased the timeout on the CPPM service as well as the ASA aaa config to 40 seconds.
  • 6.  RE: What are best practices or tips to use a RADIUS server as authentication source for ClearPass?
    Posted Apr 19, 2016 11:26 AM
    Also, I've verified with a packet capture on MFA server that a RADIUS Access-Accept(2) message is being returned to CPPM.
  • 7.  RE: What are best practices or tips to use a RADIUS server as authentication source for ClearPass?
    Posted Apr 20, 2016 04:07 PM
    bump
  • 8.  RE: What are best practices or tips to use a RADIUS server as authentication source for ClearPass?
    Posted Apr 26, 2016 09:30 AM
    It turns out that I needed to use a separate Authorization source. Before this requirement I had never written a ClearPass RADIUS service that used separate Authentication and Authorization sources. In this case, Authentication points to MFA as a RADIUS service and Authorization points to Active Directory. Thanks to TAC for helping me with this one.
