What are the different factory reset options for an IAP?
This thread has been viewed 27 times
  • 1.  What are the different factory reset options for an IAP?
    Posted Apr 08, 2016 06:38 AM
    We're used to working with Ruckus and factory defaulting here is dead easy (GUI, reset button or CLI). On an Aruba however, we haven't really found a straight forward solution to factory default an IAP. Also checking if the AP is factory reset seems tricky ...
    Could anyone help us out with a bit more information?
    Kind regards,
    Tom
  • 2.  RE: What are the different factory reset options for an IAP?
    Posted Apr 08, 2016 07:13 AM
  • 3.  RE: What are the different factory reset options for an IAP?
    Posted Apr 08, 2016 07:20 AM
    So CLI and button reset are the only 2 options you have to factory reset an Aruba AP? Is there a way, besides CLI to verify it's been factory reset?
  • 4.  RE: What are the different factory reset options for an IAP?
    Posted Apr 08, 2016 07:21 AM
    It should broadcast the "Instant" SSID when it comes up.  Is that what you mean?
  • 5.  RE: What are the different factory reset options for an IAP?
    Posted Apr 08, 2016 07:32 AM
    Oh .. because when we factory reset the IAP, we often see the 2.4 and 5 bands highlighted orange, but nothing else happening. Are we missing something here?
  • 6.  RE: What are the different factory reset options for an IAP?
    Posted Apr 08, 2016 07:34 AM
    Do you have access to the console output?  What model IAP is this?
  • 7.  RE: What are the different factory reset options for an IAP?
    Posted Apr 08, 2016 07:35 AM
    Yes, it's an IAP205.
  • 8.  RE: What are the different factory reset options for an IAP?
    Posted Apr 08, 2016 07:41 AM
    How long do you allow for it to boot up?
    You should turn it off, hold a paperclip in the reset button, put power to it for 10 seconds and then relese.
    It should take about 3 to 5 minutes for the instant SSID to show up and the a/b/g lights should turn green.
  • 9.  RE: What are the different factory reset options for an IAP?
    Posted Apr 08, 2016 07:58 AM
    That's what we do. We insert a paperclip, power on the AP, wait 10 seconds and let it boot for a couple of minutes. Then the 2.4 and 5 bands turn orange and remain orange. We've had this on a couple of IAP 205.
  • 10.  RE: What are the different factory reset options for an IAP?
    Posted Apr 08, 2016 08:30 AM
    Is it still connected to the same network with the other IAPs at this point?
  • 11.  RE: What are the different factory reset options for an IAP?
    Posted Apr 08, 2016 08:34 AM
    No, it's just an IAP on its own (that's how it was used as demo as well).
  • 12.  RE: What are the different factory reset options for an IAP?
    Posted Apr 08, 2016 09:14 AM
    Are you booting it up on a network that has DHCP and access to the internet?  If yes, can you please provide the bootup output from the console?
  • 13.  RE: What are the different factory reset options for an IAP?
    Posted Apr 08, 2016 09:26 AM
    No, just letting it boot on its own, not connected to any network or device.
  • 14.  RE: What are the different factory reset options for an IAP?
    Posted Apr 11, 2016 11:28 AM
    Here is what I do to factory reset on an IAP. I connect a console cable to it and then power up the IAP on a isolated VLAN without DHCP. Shortly after it starts to boot hit the <Enter> key to get into apboot mode. Once in apboot mode run the following commands:
    apboot> factory_reset
    apboot> purgenv
    apboot> save
    apboot> boot
    The IAP will now be factory reset.
  • 15.  RE: What are the different factory reset options for an IAP?
    Posted Apr 20, 2016 04:23 AM
    I guess I'll start doing the same, don't trust the reset button that much.
    So once you perform those commands will the Instant SSID appear instantly or do I need to do something else to check?
