Can we assume that PoE capable Switches will be used to provide - respectively on Rack 1, 2, 3 and 4 - PoE and connectivity to both PoE IP Cameras and PoE WiFi Access Points?
Is this assumption correct?
PBX should be out of the picture IF you don't have IP Phones (that's normal on non IP-PBX).
If so...what is the calculated "power budget" per Switch? I mean: how many IP Cameras and WiFi APs will be connected per Switch? what will be the power margin (growth)? this data alone is worth a discussion...because you will be then able to decide which type of PoE Switch (PoE Power) to look for.
Then, regarding the core: how many downlinks to access Switches will be made through Fiber Optic Cables (so using Fiber Optic SFP on each Fiber Optic cables' end)? Why only 5 SFP mini-GBIC Transceivers (an odd number)? will you not use them in pairs (so you will need an even number, like 4, 6, 8 and so on...)? or...are you considering SFP Modules (multi-ports) and so Sub-Modules capable Switches?
Will core do routing for your Access Switches or not?
Will there be VLAN(s)?
Will there be Port Trunks (Link Aggregations) between Core Switch and Access Switches or just a single link per Access Switch?
Have you considered a deployment with IRF Stacked Access Switches (mixing PoE with non PoE ones) and a IRF Stacked core?
Many questions...but necessary: the less details in input (questions), the less details in output (answers).
