Hi All,
Would like your help on the above topic.
Thank you!
Everything is XML API-based.
http://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=14339
Hi Cappalli,
Thanks for the info. In terms for web scripting like javascript etc? Do you have a list of such languages supported in CPPM?
Thank you.
What exactly are you trying to do?
All web scripts should work.
Internally, CPG uses the smarty template engine.
