What CA should I choose to sign IAS certificate?
  • 1.  What CA should I choose to sign IAS certificate?
    Posted Sep 10, 2012 01:10 PM
    We have a customer that is college university.
    They have and 802.1X user only authenticatoin network so users can use own devices and their staff/student domain credentials to authenticate against Windows AD, IAS RADIUS server.  The Cert on IAS server is signed by GeoTrust Global CA
    Users connect with non-domain machines, using thier own Devices.
    Windows 7 and other OS are not accepting the certifacte signed by GeoTrusts.
    A solution is to set the wireless settings to NOT Validate server certificate.
    We want a solution that requiers the least amount of configuration and management.  Customers want the simplest setup for end-user so IT staff does not have to touch all these laptops.
    Is there a Root CA that is automatically trusted by most devices, esp. windows 7?
    Is there a better way to configure this network to avoid this issue?
    thanks
  • 2.  RE: What CA should I choose to sign IAS certificate?
    Posted Sep 10, 2012 09:55 PM
    To ensure this, you would need an application that distributes the root CA and configures the WLAN devices, like Quickconnect...
    a 30-day free trial is here:  http://page.arubanetworks.com/BYODQUICKCONNECT30DayFreeTrial.html
  • 3.  RE: What CA should I choose to sign IAS certificate?
    Posted Sep 11, 2012 03:53 PM
    We use a self signed certificate which requires unchecking the validate certificate option. What we did was use the netsh command to export a working WIFI profile and then created  a batch file to import the exported profile. To make it easier, we used IExpress http://en.wikipedia.org/wiki/IExpress to wrap the files in an executable. The client runs a the small executable in Windows 7, it imports the profile, and they are prompted to enter their credentials for 802.1x.
  • 4.  RE: What CA should I choose to sign IAS certificate?
    Posted Sep 17, 2012 02:20 PM
    thanks for you ideas.
    That gives us some interesting ideas to look into.
