Wireless Water Cooler
last person joined: 23 days ago
Hang out and socialize with other community members in this off topic forum. Everything from industry trends to hobbies and interests are welcomed!
What causes a configuration mismatch on a 650 controller
  • 1.  What causes a configuration mismatch on a 650 controller
    Posted Oct 14, 2014 05:26 PM
    In Airwave I am seeing a configuration on a 650 controller.  Could this be an issue with the controller firmware version being out dated?
  • 2.  RE: What causes a configuration mismatch on a 650 controller
    Posted Oct 14, 2014 05:46 PM
    Mismatch means that the configuration at the controller and Airwave differs.
    HTH,
    Marek
  • 3.  RE: What causes a configuration mismatch on a 650 controller
    Posted Oct 14, 2014 09:31 PM
    If you are using AirWave in monitoring only mode and not intersted in configuration/mismatches, you can disable auditing on the group the device is a member of.  This will remove any mismatch messages.
