What Controller is Compatible (AP103 & AP305)
  • 1.  What Controller is Compatible (AP103 & AP305)
    Posted Jan 22, 2019 04:11 PM
    Onan auction I bought a AP103 and an AP305, a brief google search told me you the AP's had two modes IAP and AP and you could switch. (however it was never mentioned this was not . a AP->IAP conversion)
    Originally I wanted to plug the AP305 in the switch at GigE speed and 'link' to the AP103 to get wireless in a current 'bad coverage spot'.
    As I understand the contoller thing, you basically connect the AP's to the controller and the controller to the GigE switch?
    Anyways. I would like to te get the two AP's working and give the users (my family) a good connection, but not a fortune on a controller. So what are my options now?
    -- hardware controller ? (guess the 7005 is the appropiate option)
    -- software controller?  (is this available, I read about ArbubaOS and VM's but it unclear to me if that would solve the issue?)
    -- EOL Aruba controller (can be had for cheap, but will they provide the GigE access (620 is $80) with only 1 GigE port and support for ancient wifi protocols.
    -- other options?
    Any pointers would be welcome!
  • 2.  RE: What Controller is Compatible (AP103 & AP305)
    Posted Jan 22, 2019 04:58 PM
    7005 is your best bet.  You would not need a VM.
  • 3.  RE: What Controller is Compatible (AP103 & AP305)
    MVP EXPERT
    Posted Jan 22, 2019 05:18 PM
    Hi uSuRA,
    The AP support is based on the ArubaOS releases, you can find the minimum OS version in the datasheets.
    AP-103
    https://www.arubanetworks.com/assets/ds/DS_AP103Series.pdf
    Minumum version ArubaOS 6.4.0.0
    AP-305
    https://www.arubanetworks.com/assets/ds/DS_AP300Series.pdf
    Minumum version ArubaOS 6.5.0.1 / 8.1.0.0
    ArubaOS 6 is diffrent of ArubaOS 8, with AOS8 you have the oppertunity to install a mobility controller on a hypervisorplatform (esxi or hyperv).
    Please note that older controllers like the Aruba 3200XM can only run on ArubaOS 6.4.4.x and cant be used for your AP-305.
    Yes AP cant convert to IAP, so you need a controller to operate them. The smalles controller for your AP-305 is an Aruba 7000 series controller (or virtualmachine but that isnt nessesary). And dont forget you need an AP licence per AP ;) some controller come with some factory intergrated licence but iam not sure which models that are exactly, you could probarly check that in the quickspecs.
  • 4.  RE: What Controller is Compatible (AP103 & AP305)
    Posted Sep 04, 2020 04:05 PM
    What solution you end up.  7005 controller?   What about the license?
