What Default Role should I use when using clearpass?
  • 1.  What Default Role should I use when using clearpass?
    Posted Dec 13, 2019 11:49 AM
    I have two controllers and a clearpass server. I have my policy authenticating and authorizing correctly (or at least reporting it is). When I have the default role of the WLAN on the controller set to authenticated things work fine. WHen I set it to any other role we lose internet. I have the derivation method set to "use value returned from clearpass or other auth server".
    My questions:
    Whats the best default role for a WLAN to have when using clearpass to manage authentication/authorization?
    Why isn't the clearpass policy not taking prescident over the aruba controller policy?
    Thanks in advance, I'm sure its a layer 8 issue :)
  • 2.  RE: What Default Role should I use when using clearpass?
    Posted Dec 13, 2019 05:24 PM
    When CPPM is used, the default role should only serve as a fallback and really should just be configured for your guest role.
    Do you have PEF licenses installed on your controller?
  • 3.  RE: What Default Role should I use when using clearpass?
    Posted Dec 13, 2019 08:30 PM
    I think I have almost the same question, If I configure the WLAN for 'download role', but do not yet have ClearPass setup/functional, what happens? Does it break, or if ClearPass doesn't send a correct role does it just revert to the 'default' role? I am just about to start testing downloadable user roles, just curious how it's going to work.
  • 4.  RE: What Default Role should I use when using clearpass?
    Posted Dec 14, 2019 12:55 PM
    I believe it will be either the default role or the initial role.
  • 5.  RE: What Default Role should I use when using clearpass?
    Posted Dec 17, 2019 08:27 AM
    No we do not have PEF.
  • 6.  RE: What Default Role should I use when using clearpass?
    Posted Dec 17, 2019 08:28 AM
    Follow up question. would it be safe to then have authenticated as the role?
