What does log message mdns_affix_record 787 could not affix all records in a buffer mean?
  • 1.  What does log message mdns_affix_record 787 could not affix all records in a buffer mean?
    Posted Dec 15, 2015 04:08 PM
    We are currently using IAP-215 in a virtual cluster. We are seeing several messages that display with the show log system command:
    mdns|  mdns_affix_record 787 could not affix all records in a buffer.
    I'd like to understand what this means and how to address it.
  • 2.  RE: What does log message mdns_affix_record 787 could not affix all records in a buffer mean?
    Posted Dec 15, 2015 10:46 PM
    These are not errors. You should be seeing these under "warnings" and there are no issues with that. Upgrade to the latest Instant OS 4.2.x.x and these messages should not be there.
    Rajaguru Vincent
  • 3.  RE: What does log message mdns_affix_record 787 could not affix all records in a buffer mean?
    Posted Dec 15, 2015 11:13 PM
    Thanks for your reply Rajaguru.
